How remove "Remember me for 30 days" selection from login page? (v. 7.x)?
  • zabbixuser39393
    • Jan 2021
    • 38
    As topic says: How I remove "Remember me for 30 days" from login page? (v. 7.x)?
  • Answer selected by Donkey at 15-11-2024, 16:04.
    Julianna Wilamowska
    • Oct 2024
    • 34
    Hi you can change it in /usr/share/zabbix/include/views/general.login.php.
    Find lines:
    ->addItem(
    (new CCheckBox('autologin'))
    ->setLabel(_('Remember me for 30 days'))
    ->setChecked($data['autologin'])
    And comment them.
    Hope that helps.
    • Julianna Wilamowska
      • Oct 2024
      • 34
      Find lines:
      ->addItem(
      And comment them.
      Hope that helps.
      • zabbixuser39393
        • Jan 2021
        • 38
        Thanks, that did remove autologin selection... But... Logout timer seems not to work. Bug or not? Version 7.0.5
        • Frank_Eckhardt
          • May 2025
          That doesn't help.
          Unfortunately, Remember me for 30 days is always on -> Bug 1 ?
          Remember me for 30 days will change the profile of the user so that automatic logout is uncheckt.
          At the next normal login is not recheckt it again ->Bug 2?
          So there is no point in simply hiding the option.
          Bugreport?
          Version 7.0.12
          • Aer0
            • Sep 2024
            • 26
            Hello everyone.
            I didn't find that path. I use NGINX as web, is that suitable for it?
            • Donkey
              • Jun 2024
              • 24
              nginx is fine. There was a minor version update which added another folder to the path. Try
              /usr/share/zabbix/ui/include/views/general.login.php
              • Aer0
                • Sep 2024
                • 26
                Originally posted by Donkey
                nginx is fine. There was a minoor version update which added another folder to the path. Try
                That helped! Thank you!
                But that sounds like surgery way. Maybe there is an easy way just to drop off the default checkbox for the new pages?
                • kyus
                  • Feb 2024
                  • 198
                  Originally posted by Aer0
                  ...Maybe there is an easy way just to drop off the default checkbox for the new pages?
                  You can simply comment the line:
                  This should make the box unchecked by default.
                  • Donkey
                    Donkey commented
                    Bear in mind when you update Zabbix, the PHP files will get overwritten. So either back up the file or be prepared to fix it after updating.
                • Aer0
                  • Sep 2024
                  • 26
                  Thank you, guys.
                  All your advices realy helped me.
                  Just for not not create a new topic, is there any way to hard fix Auto-logout parameters in user settings?
                  We want to make a single setting for that option for all our zabbix users. Unfortunately that option can be changed by any user personally.
