Hello there!
Thank you as usual for your powerful support.
I'm introducing Zabbix in a new enterprise customer and I have to set up a P.O.C.
Context:
Through a DMZ bastion I have to check if some file are present inside a remote directory (monitor phase).
I achieve this goal by using an SSH Agent item.
The master ITEM got these informations:
FILE: 7
LBJATA1.D2024209.T114929
NZVATA1.D2024226.T114927
OIAATA1.D2024275.T114928
TFLATA1.D2024172.T114925
TXUATA1.D202403.T114931
VENATA1.D2024228.T114930
YLWATA1.D2024282.T114926
The dependent item is checking the first line of the output: FILE: 7 and Trim it to 7 (I'm using this number to fire a TRIGGER and then to start a Trigger Action by running an Agent shell script inside another node)
Needs / Questions:
Now I need to setup a Trigger that fires in case of:
> 0
AND
last is different from 0 and different from the previous one value
When 0 -> Is resolved
I need the Trigger fire when there still the files are inside that directory
Another question:
The TRIGGER is based on the dependent item, can i send the WHOLE value of the master item to a script?
Thank you very much
OC
Context:
FILE: 7
Needs / Questions:
> 0
AND
Another question:
Thank you very much
OC
