Trying to add secondary ip address in my proxy confing but it doesn't work
  • BTom
    • Sep 2024
    Hi, I'm trying to have a secondary ip address in my proxy confing, in case that the first is not working. I have it like this Server=184.21.156.234,137.61.64.14 but then the proxy doesn't work and "journalctl -xeu zabbix-proxy.service" says this: zabbix_proxy [1176119]: ERROR: "Server" configuration parameter must not contain comma but when i use semicolon the proxy starts, but i wont use the secondary ip if the first doesn't work. Any ideas on how to fix this?
  • Julianna Wilamowska
    • Oct 2024
    • 34
    Hello, it wont work like that. Zabbix supports 1 server instance for 1 proxy. If you need to monitor the second IP its best to do it separately.
    • Airler
      • Nov 2024
      Hi BTom,
      I don't know your usecase...
      But would proxy lb and ha not be the feature you are searching for?
      Then you may give the ha proxy the second ip...
      • sancho
        • Mar 2015
        • 301
        Hello BTom
        In order for you to configure 2 servers in the zabbix_proxy.conf configuration you must set it to passive mode.
        ​Merry Christmas to all.
