Dashboard: Widget size
  • christianmolecki
    • Nov 2017
    • 24
    Is there a setting to adjust the width of the widgets?
    BR
    Christian
  • Answer selected by christianmolecki at 19-11-2024, 10:57.
    christianmolecki
    • Nov 2017
    • 24
    I know, but thats a static width,
    Is there a auto size according to the browser?
    • mrnobody
      mrnobody commented
      Zabbix is responsive, but maps and dashboards can't be 100% responsive to the browser.
      It's not a good pratical and will need to be redo in every packages upgrade, but; i do something like this in CSS, editing your /usr/share/zabbix/assets/themeyouuse.css
      .dashboard-grid-widget-content{
      width: 200% !important;
      It will overwrite existing rules from native CSS, with your custom CSS code. You can test directly on your browser using inspect element and changing the values...
    • 4958
    Edit and pull them wider?
    • christianmolecki
      • Nov 2017
      • 24
      • mrnobody
        mrnobody commented
