I have a Zabbix Agent check that returns a value every 10 minutes, say for example 0.
I have configured an item to run the check, which returns the correct value.
What I want to get going are three triggers, as below:-
1) Warning = difference between last value and previous value is 1
2) Average = difference between last value and previous value is 2
3) High = difference between last value and previous value is more than 2
So far, I have come up with the following triggers for each item:-
1) {Custom:custom.check.test.change()} = 1
1) {Custom:custom.check.test.change()} = 2
1) {Custom:custom.check.test.change()} > 2
These use the 'change' trigger which should compare the value of the last and previous values.
As a test, I have the check reading the contents of a file starting with the value set to 0. If I change the value to 1, it triggers all 3 triggers, when it should just trigger the 1st.
Can anyone find what I'm doing wrong?
All help greatly appreciated.
Duncan.
Duncan.
