Migrating Zabbix 6.4 from CentOS 8 Stream to Rocky 9 with existing PoatgreSQL DB
  • Gofaizen
    • Apr 2022
    Hello....
    I have Zabbix server 6.4.19 on CentOS 8 Stream with PostgreSQL and TimescaleDB backend on separate server.
    Can I install fresh Zabbix server 6.4.19 on Rocky Linux 9 and use existing database ?
    Regards....
    • 5002
    short asnwer - yes....
    • Gofaizen
      • Apr 2022
      Thanks....
      I see migration like this :
      1. Install fresh Zabbix server on Rocky 9.
      2. Copy server and agent configs from old installation.
      3. Configure SELinux.
      4. Start new Zabbix server and agent.
      Am I right ? Or I need some more steps ?
        • 5002
        I think there is also a config for UI somewhere, what you need...
        • Gofaizen
          • Apr 2022
          Thanks...
          Trying to find UI config.
          • Gofaizen
            • Apr 2022
            Hello...
            UI config lives in database.
            I have successfully launched new server with existing database and settings.
            Now I have same Zabbix Server on new Rocky Linux 9.
              • 5002
              I meant "conf/zabbix.conf.php" file for your UI. It is not a server conf or agent conf, what you mentioned for copying..
              • Gofaizen
                • Apr 2022
                Thank You for advice.
                I copied /etc/zabbix/*. In my case file zabbix.conf.php lives in /etc/zabbix/web.
                Also I copied snmp configs and MIB files from old system.
                Now zabbix works as I expected.
