Setting Triggers for Master and Dependent CPU Idle Time and Utilization Items
  • sulemmuh
    • Nov 2024
    I am working with the "Linux by Zabbix server agent" template, which provides two items for monitoring CPU:
    1. CPU idle time (system.cpu.util[,idle]): This is the master item.
    2. CPU utilization (system.cpu.util): This is the dependent item.
    I have set up triggers for both items separately, with CPU utilization dependent on CPU idle time, but I am encountering issues, and the triggers are not working as expected.
    Here are the triggers I attempted to configure:
    CPU idle time:This should alert if CPU idle time drops below 10%.
    last(/zabbix-centos9testbox.pacific.edu/system.cpu.util[,idle]) < 10
    CPU utilization:This should alert if CPU utilization exceeds 90%​
    last(/zabbix-centos9testbox.pacific.edu/system.cpu.util) > 90​
    Both items were configured using the "Linux by Zabbix server agent" template, but I suspect there may be issues with the dependency or the expressions themselves.
    How can I properly configure these triggers so they work as intended, considering the master and dependent item relationship?
