Template graph not showing in host
  • aseques
    • May 2019
    • 40
    Hi, I'm on 7.0.5 and I created a template from scratch to monitor a datastore, I attached the template to a host (the datastore system) and the values are showing as expected. On the template I created a graph too, with some of the metrics that are shown in the host, but in this case it doesn't show.
    This is the template page
    On the graph view for the host doesn't show anything
  • aseques
    • May 2019
    • 40
    I am replying myself because I found the solution and it might help someone with the same situation, it was a silly filter I used for another host, it seems that the filters are kept active even when changing the hosts, so in my case it was a matter of removing the filter and then the graphs showed immediately.
    • troffasky
      • Jul 2008
      • 640
      Yeah, I think this is a bug. It does not make any sense to apply a tag filter to a host, that does not even have that tag on it.
      • troffasky
        • Jul 2008
        • 640
        https://support.zabbix.com/browse/ZBX-21916 been around for a while now.
