Zabbix and Node-red
  • NieR
    • Oct 2024
    Zabbix and Node-red
    I recently started working with nodered and I installed node-red-contrib-zabbix-sender (node) - Node-RED in my Node-red and as far i'm concerned i'm sending data to zabbix, but I can't figure out how to show it, so I can monitorize correctly.
    Here’s the data I’m working with:
    • Host: X
    • Data Probe: ProbeX (ranging from 1 to 6)
    • Degrees: XX.X
    Any help or guidance would be greatly appreciated.
    Thanks in advance!
    • 5002
    Did you do all required config on Zabbix side? Host(s), items etc?
    It is not just send it somewhere...
    • NieR
      • Oct 2024
      Hi, thanks for you reply, I tried but can't figure how to show the data in zabbix, tried creating the host and items, but it doesn't work.
      I'm pretty new to zabbix, so as I said any help or guidance is appreciated
        • 5002
        Have you tried manual ? https://www.zabbix.com/documentation/current/en/manual
        based on examples from your linked page
        you need a host called "Host: X" and items "Probe1" to "Probe6" (name and key set to "Probe<whatever number it is>", type trapper, value type float). Somehow on the other side you need to configure zabbix server location and then send data away. You should see arrived data under "Latest data"
