CPU busy time
  • jvillain
    • Apr 2014
    • 12
    CPU busy time
    I am trying to create a "cpu busy time" calculated item in the "Linux OS template" which would just flip the idle time graph upside down because my manager is to stupid to cope with idle time. I am trying to create a calculated item that would be 100 - idle time.
    I have tried the following
    100-last("system.cpu.util[,idle]")
    100 - last("system.cpu.util[,idle]")
    "100-last("system.cpu.util[,idle]")"
    100 - last(system.cpu.util[,idle])
    All come back with bad syntax errors. Can any one tell me what I am doing wrong? Thanks in advance.
  • guzzijason
    • Dec 2015
    • 106
    I set up a test item using
    and it worked just fine on zabbix 3.0.4.
    __Jason
    • jvillain
      • Apr 2014
      • 12
      Thank you __Jason. I got it working.
