Hello all,
i was wondering if this is possible in Zabbix.
I have some triggers on 2 different hosts.
For example
I have trigger1 on host1
I have trigger2 on host2
I have set these alarms to information
I want to make an alarm, based on if trigger1 and trigger2 are active on the same time. If only one trigger is active, i dont want to make an alarm.
Can i make a "fake" host which looks into these triggers and will make an alarm if both are active at the same time?
Best regards
Kris
For example
Best regards
Kris
