I have an internal EasyRSA Certificate Authority with a root CA installed on all my servers (including the zabbix server, and Ubuntu 24.04 box). I am using the built in certificate validation template (https://www.zabbix.com/integrations/ssl) but the cert is showing as invalid, with the specific failure listed as "failed to verify certificate: x509: certificate signed by unknown authority". I don't see an option in the config or macros to specify a root CA, and I'm wondering how to indicate that. I validated the root certificate is in the server's cert store, and I can verify the ssl cert is fully valid with CURL.
Help with SSL Validation on a domain with a cert signed by an internal CA?
