Prevent or filter discovered items
  • etfz
    • Apr 2024
    • 19
    I have some VMware virtual machines with filesystem discovery, and I've just noticed that each ZFS snapshot is discovered as a filesystem. This clutters the data, and I would to eliminate these. Besides disabling filesystem discovery altogether - which I'm not ruling out, as I intend to use agent based file system monitoring - I have a few ideas, none of which I know how to do.
    - Disable if a certain template is applied to the host
    - Disable if a certain tag is present on the host
    - Omit file systems whose name contain a certain string (undesirable)
  • Answer selected by etfz at 25-11-2024, 16:49.
    cyber
    • 4940
    vmware guest "mounted fielsystems" discovery has no filters set..Only LLD macro there is {#FSNAME}.. so you can only add a filter based on that... either does not match regex or matches regex...
      • 4940
      • etfz
        • Apr 2024
        • 19
        That works, but I don't really like it. No way for the other methods? (disabling all file system discovery based on host template or tag?
          • 4940
          nope.. there is nothing like "if this tag exists on a host, don't run template X"...
          • etfz
            • Apr 2024
            • 19
            I understand. Thanks. In the end, I've opted to disable filesystem discovery across the board.
