Help modifying a template
  • doogiehausermd
    • Oct 2024
    Hi there, having some issues with the template FortiGate by SNMP as subject says. I posted this to reddit but I thought posting here might be a better idea.
    Lots of the values are coming up with no OID found for my access points utilizing this template. For example ,"Preprocessing failed for: .1.3.6.1.4.1.12356.101.14.4.3.1.1.1.16.70.80.52.51 .snip.50.snip.50 = STRING: ... 1. Failed: unable to extract value for given OID: no data was found" for memory capacity for each AP.
    I have dug in and see that clicking on the item it says, wc.mem.size[fgWcWtpSessionWtpMemoryCapacity.1.3.6.1.4.1.12356. 101.14.4.3.1.1.1.16.70.80.52.51.snip.50.snip.50]. Now, I know no OID is really that long so my issue is in that item config itself. So I backed up a level via the web UI here to Wireless Discovery, which has the key as wc.mem.size[fgWcWtpSessionWtpMemoryCapacity.{#SNMPINDEX}] and the master item is the "SNMP walk wireless AP" item.
    If I manually walk it, I get the proper data, but I have no idea how to translate the serial number in quotes into, well, something manageable in Zabbix so this can work. Obviously {#SNMPINDEX} is my issue. Is there a way I can implement quotation marks on it? I tried wc.mem.size[fgWcWtpSessionWtpMemoryCapacity."{#SNMPINDEX}"] without luck. What is the right way to properly modify the template to capture this data below?
    Click image for larger version  Name:	Screenshot 2024-11-25 at 1.47.29 PM.png Views:	28 Size:	136.9 KB ID:	494870
    support@zbx-proxy:~$ snmpwalk -v2c -c public -m +FORTINET-FORTIGATE-MIB 10.10.14.1 FORTINET-FORTIGATE-MIB::fgWcWtpSessionWtpMemoryCapacity
    FORTINET-FORTIGATE-MIB::fgWcWtpSessionWtpMemoryCapacity.1."FP432FTFXX XXXX1" = Gauge32: 891288
    FORTINET-FORTIGATE-MIB::fgWcWtpSessionWtpMemoryCapacity.1."FP432FTFXX XXXX2" = Gauge32: 891288
    FORTINET-FORTIGATE-MIB::fgWcWtpSessionWtpMemoryCapacity.1."FP432FTFXX XXXX3" = Gauge32: 891288
    FORTINET-FORTIGATE-MIB::fgWcWtpSessionWtpMemoryCapacity.1."FP432FTFXX XXXX9" = Gauge32: 891288
    Can someone give me some guidance on where to start trying to fix this?
  • troffasky
    • Jul 2008
    • 639
    Is that space really there in that OID? You can't edit a discovered item, but I suggest that you manually create it, identical to how it is discovered BUT without the space in the OID. Or snmpget that one OID, without the space.
    You can also use "snmptranslate -On <some OID>" to get the numeric OID.
    • doogiehausermd
      • Oct 2024
      The space is not there, sorry about that. I didn’t even realize it was there when I pasted it
      • doogiehausermd
        • Oct 2024
        So Zabbix is converting the serial number to decimal, and I need to get it to stop doing so. Off to the manuals... will update if I find the right answer.
        • mrnobody
          mrnobody commented
          Nop, Zabbix is not converting in this case.
          LLD (Low Level Discovery) as it name says, is low level, it's more readable for machine than we humans.
          In other words, for example; you can walk directly OID for know all interfaces operational status like:
          snmpwalk -v2c -c public 10.10.14.1 1.3.6.1.2.1.2.2.1.8
          It returns all states of interfaces, and a lot of OID numbers, like machines want! And remember, Zabbix is a software that run on machines, so it likes it too
          And you can do the same thing, with translated information:
          snmpwalk -v2c -c public 10.10.14.1 IF-MIB::ifOperStatus
          It returns same data, but without OID numbers, only with human "more readable" information.
          Inside Zabbix you can use both, translated or directly OID.
          So, like troffasky said, use snmptraslate.
          In my example
          Command: snmptranslate -On IF-MIB::ifOperStatus
          Returns: .1.3.6.1.2.1.2.2.1.8
          In your case, snmptraslate
          Command: snmptranslate -On FORTINET-FORTIGATE-MIB::fgWcWtpSessionWtpMemoryCapacity
          Returns: OID you are searching for.
          If you need to manipulate the OID inside of Zabbix, after getting it without translations, i suggest using preprocessing + JS.
          And, if you want to concatenate OID result + {#SNMPINDEX}, don't use ""
      • Fossil2876
        • Mar 2025
        Did you ever find the solution to this? I am having a similar issue with the template.
        • Fossil2876
          • Mar 2025
          If anyone else has the issue from the WTP SNMP walk value in the default template it seems like the snmp walk in the Master Item needed to be bumped up a bit to allow for all of the information that was discovered to populate.
          I change: SNMP walk wireless AP
          SNMP OID: from walk[1.3.6.1.4.1.12356.101.14.4.3.1] to walk[1.3.6.1.4.1.12356.101.14.4] and now the data loads for the unsupported items on the APs.
