Use Global Variable for Macro Value in a custom Template
  • shafuq
    • Oct 2024
    • 17
    I'm using a template "Alcatel-Lucent Enterprise OmniSwitch AOS 6.x" from zabbix github.
    It comes with three macro values that need to be filled as described in its document:
    "Open "Configuration -> Templates -> Template Alcatel-Lucent Enterprise OmniSwitch AOS 6.x -> Macros" and set the three entries."
    I already have snmpv3user {$SNMPv3PW} and snmpv3pw {$SNMPv3PW} global variables set in Zabbix for other similar templates. So I would like to know if I could fill in this template's macro fields with these global variables instead of repeating the same values.
    For example, can I use the following within this template's Macros section:
    MACRO/VALUE:
    {$SNMP_V3_AUTHPASSPHRASE} = {$SNMPv3PW}
    {$SNMP_V3_PRIVPASSPHRASE} = {$SNMPv3PW}
    {$SNMP_V3_USER} = {$SNMPv3_USR}
    Instead of:
    MACRO/VALUE:
    {$SNMP_V3_AUTHPASSPHRASE} = MySnmpPW
    {$SNMP_V3_PRIVPASSPHRASE} = MySnmpPW
    {$SNMP_V3_USER} = MySnmpUserName
    Thanks in advance!
  • Answer selected by shafuq at 28-11-2024, 14:36.
    cyber
    • 4985
    If you think a bit... Where those macros are being used?
    In v6 you configure all snmp credentials in hosts config, they are not used in item config, so those macros are kind of useless...
    I think this template has been upgraded from older version and macros have not been removed...
    • shafuq
      • Oct 2024
      • 17
      This seems like a very basic question. Googling it returns no results. Are there no senior zabbix users out there that can answer yes/no?
        • 4985
        • shafuq
          • Oct 2024
          • 17
          You are right, after examining the yaml file I noticed the macros weren't used anywhere.
          Thanks!
