Server does not receive data from my first agent in active mode.
  • PmGs
    • Nov 2024
    • 17
    Hello All,
    I installed a Zabbix for the first time. I installed it with Promox Helper and my server is running in version 7.0.6
    I enter a first new host, a virtual machine (lxc on the same local network but not in proxmox).
    I used template "Linux by Zabbix agent active" first with standard Agent then with Agent2.
    In both case, I changed "Server" and "ServerActive" in my agent config file.
    But the server does not receive any data* and I see no "alert" message in the log except this one that I don't understand.
    lowering the plugin ZabbixSync capacity to 1 as the configured capacity 1000 exceeds limits
    * and get this problem message : Zabbix agent is not available (or nodata for 30m)
    Thanks in advance for any help.
  • Answer selected by PmGs at 28-11-2024, 11:36.
    PmGs
    • Nov 2024
    • 17
    Found but strange.
    In my host config I had this template "Linux by Zabbix agent active" but when I clicked on it, it opened a "template windows" and in this window the "Templates" field was empty!
    I selected "Linux by Zabbix agent active" and everything works now.
    Strange ... we can change the template of a template!?
    • PmGs
      • Nov 2024
      • 17
      Found but strange.
