Calculated Item in Interface Discovery
  • Behemoth
    • Jun 2015
    I’m trying to create a calculated item from values in interface discovery, but I haven’t really figured out how yet. I think the documentation is pretty clear, but somehow it isn’t working in my system. I’m running Zabbix 2.4.8.
    So, I need to see incoming packets per second (pps) on all interfaces on a router. I have collected three values from my interface discovery rules: ifHCInBroadcastPkts, ifHCInMulticastPkts and ifHCInUcastPkts. These are working fine and I get data from each one. In order to get pps, I need to combine these into a new item.
    So I created an Item Prototype in my discovery rules like this:
    Name: {#SNMPVALUE} - ifHCInPkts
    Type: Calculated
    Key: ifHCInPkts.[{#SNMPINDEX}]
    and I’ve tried these four exact formulas:
    Formula:
    last(”ifHCInBroadcastPkts.[{#SNMPVALUE}]”)+last(”ifHCInMulticastPkts.[{#SNMPVALUE}]”)+last(”ifHCInUcastPkts.[{#SNMPVALUE}]”)
    last(”ifHCInBroadcastPkts[{#SNMPVALUE}]”)+last(”ifHCInMulticastPkts[{#SNMPVALUE}]”)+last(”ifHCInUcastPkts[{#SNMPVALUE}]”)
    last(”ifHCInBroadcastPkts.[{#SNMPINDEX}]”)+last(”ifHCInMulticastPkts.[{#SNMPINDEX}]”)+last(”ifHCInUcastPkts.[{#SNMPINDEX}]”)
    last(”ifHCInBroadcastPkts[{#SNMPINDEX}]”)+last(”ifHCInMulticastPkts[{#SNMPINDEX}]”)+last(”ifHCInUcastPkts[{#SNMPINDEX}]”)
    But the only thing I see is this error:
    Cannot evaluate function "last()": item ”router01:”ifHCInBroadcastPkts[{#SNMPINDEX}]”" does not exist
    What am I doing wrong?
  • batchenr
    • Sep 2016
    • 440
    Type: Calculated
    Formula:
    i might be worng but shouldnt it be like this : ?
    (”ifHCInBroadcastPkts.[{#SNMPINDEX}].last()”) and (”ifHCInMulticastPkts.[{#SNMPINDEX}].last()”) and (”ifHCInUcastPkts.[{#SNMPINDEX}].last()”)
    • Behemoth
      • Jun 2015
      I tried your suggestion but now I get the following error message:
      Invalid first parameter in function [last()].
      • batchenr
        • Sep 2016
        • 440
        see if helps :
        http://stackoverflow.com/questions/7...multiple-items
        • glebs.ivanovskis
          • Jul 2015
          • 237
          If you are trying to sum all discovered items into one, currently it is not possible without "manual labor" or API scripting.
          • Behemoth
            • Jun 2015
            OK, thanks. What does "manual labor" mean?
            • robert.s
              • Nov 2021
              I know this is resurrecting an old issue but I had the same issue and finally figured it out
              sum(last_foreach(//ifHCInBroadcastPkts[*]))
              should get what you need. I am also putting this here for my own use when I search this again as I inevitably will.
