tls_psk_identity - now unique?
  • grefabu
    • Jul 2019
    • 44
    I cant' sy since when this occoure but when I define a new Host with an tls_psk_identity that is allready there I got:
    Invalid parameter "/1/tls_psk": another tls_psk value is already associated with given tls_psk_identity.
    Formerly I didn't got this message.
    The problem is: I deploy the zabbix agent with an tool with the same settings for the hosts. So they've all the same Identity and PSK.
    I'm sure in zabbis 6.x this works.
    And when I clone an given host, the tls_psk_identity is the same too?
    When I've to give the tls_psk_identity individual, I've to made it on all hosts manual,...
    Bye
    Gregor
    • 4985
    one identity cannot have multiple values, thats what it says... so maybe you have somewhere a typo?
    Each PSK identity must be paired with only one value. It is the user's responsibility to ensure that there are no two PSKs with the same identity string but different values. Failing to do so may lead to unpredictable errors or disruptions of communication between Zabbix components using PSKs with this PSK identity string.
    • grefabu
      • Jul 2019
      • 44
      thank you. That clarified my misbehavior, I wasn't aware about this circumstance.
      Bye
      Gregor
