Trigger tags - What macros can be used?
  • Jason
    • Nov 2007
    • 431
    With a zabbix 3.2.3 server I've been having a play with tags on triggers and at https://www.zabbix.com/documentation...ers/event_tags it seems to says that user macros can be used for the tag value as well as item.value and item.lastvalue
    However, on a test host I've tried the following
    {TRIGGER.STATUS} - not resolved
    {EVENT.VALUE} - not resolved
    {ITEM.VALUE} - resolved ok.
    Is there a definitive list of what macros can be used here?
  • glebs.ivanovskis
    • Jul 2015
    • 237
    You've answered your own question: user macros, {ITEM.VALUE} and {ITEM.LASTVALUE}. User macros are those who start with $.
    • Jason
      • Nov 2007
      • 431
      So apart from user macros there are only 2 that can be used?
