zabbix java gateway not properly reading in properties
  • db100
    • Feb 2023
    • 62
    i am starting the java gaeway container with this env:
    • name: JAVA_OPTIONS
      value: "-Dcom.sun.management.jmxremote.authenticate=false -Dcom.sun.management.jmxremote.ssl=false -Dcom.sun.management.jmxremote.registry.ssl=false"
    as i want to connect it to a remote endpoint without auth and without SSL.
    this props are correctly passed to the java --server command (verified with ps aux) but i still get this error in console:
    2024-11-29 12:18:24.999 [pool-2-thread-4] DEBUG com.zabbix.gateway.SocketProcessor - error caused by
    java.io.EOFException: null
    at java.base/java.io.DataInputStream.readFully(DataInputStream. java:203)
    at java.base/java.io.DataInputStream.readFully(DataInputStream. java:172)
    at com.zabbix.gateway.BinaryProtocolSpeaker.getReques t(BinaryProtocolSpeaker.java:51)
    at com.zabbix.gateway.SocketProcessor.run(SocketProce ssor.java:52)
    at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1136)
    at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:635)
    at java.base/java.lang.Thread.run(Thread.java:840)
    2024-11-29 12:18:24.999 [pool-2-thread-4] DEBUG c.z.gateway.BinaryProtocolSpeaker - sending the following data in response: {"response":"failed"}
    2024-11-29 12:18:25.000 [pool-2-thread-2] DEBUG com.zabbix.gateway.SocketProcessor - finished processing incoming connection
    2024-11-29 12:18:25.000 [pool-2-thread-4] DEBUG com.zabbix.gateway.SocketProcessor - finished processing incoming connection
    2024-11-29 12:18:26.593 [pool-2-thread-5] DEBUG c.z.g.ZabbixJMXConnectorFactory - connecting to JMX agent at 'service:jmx:rmi:///jndi/rmi://<host and port>/jmxrmi'
    2024-11-29 12:18:26.998 [pool-2-thread-5] WARN com.zabbix.gateway.SocketProcessor - error processing request, item "jmx["kafka.controller:type=KafkaController,name=Re plic asToDeleteCount","Value"]" failed: SSL peer shut down incorrectly: service:jmx:rmi:///jndi/rmi://<host and port>/jmxrmi
    2024-11-29 12:18:26.999 [pool-2-thread-5] DEBUG com.zabbix.gateway.SocketProcessor - error caused by
    com.zabbix.gateway.ZabbixException: SSL peer shut down incorrectly: service:jmx:rmi:///jndi/rmi://<host and port>/jmxrmi
    at com.zabbix.gateway.JMXItemChecker.getValues(JMXIte mChecker.java:168)
    at com.zabbix.gateway.SocketProcessor.run(SocketProce ssor.java:76)
    2024-11-29 12:18:26.999 [pool-2-thread-5] DEBUG c.z.gateway.BinaryProtocolSpeaker - sending the following data in response: {"response":"failed","error":"SSL peer shut down incorrectly: service:jmx:rmi:\/\/\/jndi\/rmi:\/\/<host and port>\/jmxrmi"}
    therefore i am assuming that SSL is still being tried? "SSL peer shut down incorrectly"
    ref: https://github.com/zabbix/zabbix-docker/issues/1576
