vulnerabilities zabbix
  • Thomas51
    • Oct 2024
    • 19
    I just saw that several security vulnerabilities have been published for Zabbix. I have version 7.0. How can I update it to fix the vulnerabilities?
    I tested the following commands:
    wget https://repo.zabbix.com/zabbix/7.0/d...bian12_all.deb
    dpkg -i zabbix-release_latest+debian12_all.deb
    apt update
    apt install --only-upgrade zabbix-server-mysql zabbix-frontend-php zabbix-agent
    But it says everything is up to date...
    How can I fix the security vulnerabilities?
    • 5002
    What minor version of 7 you have ? Article mentions 7.0.0 and upgrade to 7.0.1rc1, but if you have something higher, it should be fixed there already...
    • Thomas51
      • Oct 2024
      • 19
      I have version 7.0.5, but I've had this version for 2 weeks. What do you think?
      Another article mentions Zabbix versions 7.0.x prior to 7.0.4rc1, and I'm not sure if I'm affected since I'm not on rc1.
        • 5002
        you have 7.05 which is later than 7.0.4rc1...
        • Thomas51
          Thomas51 commented
          Thank you, this also concerns the agents, they are in 6.4.?
        • 5002
        Why I need to quote the text that is on the page you linked?
        Zabbix said three product versions are affected and should be upgraded to the latest available:
        • 6.0.0…6.0.31
        • 6.4.0…6.4.16
        • 7.0.0
        Upgrading to versions 6.0.32rc1, 6.4.17rc1, and 7.0.1rc1 respectively will protect users from the privilege escalation attacks.
        Mentioned fixed rc1 versions (release candidate 1) came out already in July
        Any later version is also safe.... Currently, as of 5th of December 2024 latest vesions are 6.0.36, 6.4.20, 7.0.6, which came out already on 19-20 of November... Before that article was written...
