Hi All,
I have been trying out Zabbix 3.2.4 installed on Ubuntu 16.04, my intention is to make the email notification work, by using custom script to send email using gmail.
I have referred the instruction at
the notification script ( in /usr/lib/zabbix/alertscripts/notification.sh ) which I have made is working fine, when running from command line with parameters given.
I have given media information for the user. Created action, in actions for operation field , I have given the correct user and media type .
I have done 8 times the setup on fresh installation today, I am referred the docs and exactly the same I have done, but I am not able to get the email notification using the custom script , and in the Reports=> Notification also I do not see any entry for the users
Since I have done the same steps today repeatedly, as per the document and not getting the results, like to know whether any one else also faced the same issues for using custom scripts for gmail notification.
Like to hear from the testing department, on this issue.
Joseph John
Joseph John
