ORA-00942: table or view does not exist
  • aprakash
    • Mar 2017
    • 21
    Hi Team,
    We are using oracle DB for Zabbix server.
    While trying to start Zabbix server, we are getting below error
    27703:20170306:084424.889 In zbx_db_get_database_type()
    27703:20170306:084424.889 In DBconnect() flag:0
    27703:20170306:084424.936 query without transaction detected
    27703:20170306:084424.936 query [txnlev:0] [alter session set nls_numeric_characters='. ']
    27703:20170306:084424.937 End of DBconnect():0
    27703:20170306:084424.937 query [txnlev:0] [select * from (select userid from users) where rownum<=1]
    27703:20170306:084424.939 [Z3005] query failed: [-1] ORA-00942: table or view does not exist [select * from (select userid from users) where rownum<=1]
    27703:20170306:084424.939 cannot select records from "users" table
    27703:20170306:084424.940 End of zbx_db_get_database_type():ZBX_DB_UNKNOWN
    27703:20170306:084424.940 cannot use database "OMSALD": database is not a Zabbix database
    Please let us know whether we need to create any table in DB End before start the zabbix server. If yes, please provide some more information
    From ORACLE DB End, we just created schema alone
  • Atsushi
    • Aug 2013
    • 2028
    Please do not only create the schema but also register the initial data.
    It is also necessary to load images.sql and data.sql.
    • aprakash
      • Mar 2017
      • 21
      Followed and create all DB scripts.. still i am facing same error while
      https://www.zabbix.com/documentation...all/db_scripts
      Followed and create all DB scripts.. still i am facing same error while trying to start zabbix server
      21187:20170312:053507.753 In zbx_db_get_database_type()
      21187:20170312:053507.753 In DBconnect() flag:0
      21187:20170312:053507.771 [Z3001] connection to database '//xxxx:1521/xxx' failed: [-1]
      21187:20170312:053507.771 Cannot connect to the database. Exiting...
      • aprakash
        • Mar 2017
        • 21
        Any update ? i am still getting same issue
        10577:20170330:060258.541 Starting Zabbix Server. Zabbix 3.2.3 (revision 64610).
        10577:20170330:060258.549 ****** Enabled features ******
        10577:20170330:060258.549 SNMP monitoring: NO
        10577:20170330:060258.549 IPMI monitoring: NO
        10577:20170330:060258.549 Web monitoring: YES
        10577:20170330:060258.549 VMware monitoring: NO
        10577:20170330:060258.549 SMTP authentication: NO
        10577:20170330:060258.549 Jabber notifications: NO
        10577:20170330:060258.549 Ez Texting notifications: YES
        10577:20170330:060258.549 ODBC: NO
        10577:20170330:060258.549 SSH2 support: NO
        10577:20170330:060258.549 IPv6 support: NO
        10577:20170330:060258.549 TLS support: NO
        10577:20170330:060258.550 ******************************
        10577:20170330:060258.550 using configuration file: /tools/appsw/oracle/zabbix/etc/zabbix_server.conf
        10577:20170330:060258.550 In zbx_load_modules()
        10577:20170330:060258.550 End of zbx_load_modules():SUCCEED
        10577:20170330:060258.550 In init_database_cache()
        10577:20170330:060258.550 In zbx_mem_create() descr:'history cache' param:'HistoryCacheSize' size:16777216
        10577:20170330:060258.550 zbx_shmget() removing existing shm_id:272039993
        10577:20170330:060258.550 valid user addresses: [0x7f64c5dc3170, 0x7f64c6dc2ff0] total size: 16776832
        10577:20170330:060258.550 End of zbx_mem_create()
        10577:20170330:060258.550 In zbx_mem_create() descr:'history index cache' param:'HistoryIndexCacheSize' size:4194304
        10577:20170330:060258.550 zbx_shmget() removing existing shm_id:272072762
        10577:20170330:060258.550 valid user addresses: [0x7f64c59c3180, 0x7f64c5dc2ff0] total size: 4193904
        10577:20170330:060258.550 In init_trend_cache()
        10577:20170330:060258.550 In zbx_mem_required_size() size:0 chunks_num:1 descr:'trend cache' param:'TrendCacheSize'
        10577:20170330:060258.550 End of zbx_mem_required_size() size:422
        10577:20170330:060258.550 In zbx_mem_create() descr:'trend cache' param:'TrendCacheSize' size:4194304
        10577:20170330:060258.550 zbx_shmget() removing existing shm_id:272105531
        10577:20170330:060258.550 valid user addresses: [0x7f64c55c3170, 0x7f64c59c2ff0] total size: 4193920
        10577:20170330:060258.550 End of init_trend_cache()
        10577:20170330:060258.550 End of init_database_cache()
        10577:20170330:060258.550 In init_configuration_cache() size:8388608
        10577:20170330:060258.550 In zbx_mem_create() descr:'configuration cache' param:'CacheSize' size:7130317
        10577:20170330:060258.550 zbx_shmget() removing existing shm_id:272138300
        10577:20170330:060258.550 valid user addresses: [0x7f64c4ef6170, 0x7f64c55c2cc0] total size: 7129936
        10577:20170330:060258.550 In zbx_strpool_create()
        10577:20170330:060258.550 In zbx_mem_create() descr:'string pool' param:'CacheSize' size:1258291
        10577:20170330:060258.550 zbx_shmget() removing existing shm_id:272171069
        10577:20170330:060258.550 valid user addresses: [0x7f64c4dc2168, 0x7f64c4ef5328] total size: 1257920
        10577:20170330:060258.550 End of zbx_strpool_create()
        10577:20170330:060258.550 End of init_configuration_cache()
        10577:20170330:060258.550 In init_selfmon_collector()
        10577:20170330:060258.550 init_selfmon_collector() size:7344
        10577:20170330:060258.550 zbx_shmget() removing existing shm_id:272203838
        10577:20170330:060258.550 End of init_selfmon_collector() collector:0x7f64c4dc0000
        10577:20170330:060258.550 In zbx_vc_init()
        10577:20170330:060258.551 In zbx_mem_required_size() size:0 chunks_num:1 descr:'value cache size' param:'ValueCacheSize'
        10577:20170330:060258.551 End of zbx_mem_required_size() size:427
        10577:20170330:060258.551 In zbx_mem_create() descr:'value cache size' param:'ValueCacheSize' size:8388608
        10577:20170330:060258.551 zbx_shmget() removing existing shm_id:272236607
        10577:20170330:060258.551 valid user addresses: [0x7f64c45c0170, 0x7f64c4dbfff0] total size: 8388224
        10577:20170330:060258.551 End of zbx_mem_create()
        10577:20170330:060258.551 End of zbx_vc_init()
        10577:20170330:060258.551 In zbx_db_get_database_type()
        10577:20170330:060258.551 In DBconnect() flag:0
        10577:20170330:060258.582 [Z3001] connection to database '//abcda.abcd.com:1521/OMSALD' failed: [-1]
        10577:20170330:060258.582 Cannot connect to the database. Exiting...
        • Atsushi
          • Aug 2013
          • 2028
          Have you set up the necessary environment variables to connect to Oracle?
          • aprakash
            • Mar 2017
            • 21
            Yes.. How to verify that..
            https://www.zabbix.com/forum/showthread.php?t=49925
            when i am starting zabbix server.. getting below error
            ./zabbix_server: error while loading shared libraries: libclntsh.so.11.1: cannot open shared object file: No such file or directory
            so i am exporting export LD_LIBRARY_PATH=/tools/utilsw/oracle/11gclient/lib
            then i started the server.. After startup.. i am seeing those exception in logs
            During zabbix server compilation, i used below syntax
            ./configure --prefix=/tools/appsw/oracle/zabbix --enable-server --enable-agent --with-oracle=yes --with-oracle-include=/tools/utilsw/oracle/11gclient/rdbms/public --with-oracle-lib=/tools/utilsw/oracle/11gclient/lib --with-libcurl
            Update:
            I followed below
            export ORACLE_HOME=/tools/utilsw/oracle/11gclient
            export LD_LIBRARY_PATH=$ORACLE_HOME/lib
            export PATH=$PATH:$ORACLE_HOME/bin
            and i am seeing below logs
            11235:20170330:082621.483 there is at least 1 record in "users" table
            11235:20170330:082621.484 End of zbx_db_get_database_type():ZBX_DB_SERVER
            11235:20170330:082621.484 In DBcheck_version()
            11235:20170330:082621.484 In DBconnect() flag:0
            11235:20170330:082621.504 query without transaction detected
            11235:20170330:082621.504 query [txnlev:0] [alter session set nls_numeric_characters='. ']
            11235:20170330:082621.504 End of DBconnect():0
            11235:20170330:082621.504 query [txnlev:0] [select 1 from tab where tabtype='TABLE' and lower(tname)='dbversion']
            11235:20170330:082621.517 query [txnlev:0] [select mandatory,optional from dbversion]
            11235:20170330:082621.520 Cannot get the database version. Exiting ...
            As per document, https://www.zabbix.com/documentation...all/db_scripts
            All the scripts are created in DB server
            • aprakash
              • Mar 2017
              • 21
              Any update on this ?
              when i check DB side.. i see TABLE Exists.. what else required ?
              SQL> select * from session_privs;
              PRIVILEGE
              CREATE SESSION
              CREATE TABLE
              CREATE PROCEDURE
              SQL> select 1 from tab where tabtype='TABLE' and lower(tname)='dbversion';
              1
              1
              SQL> select * from DBVERSION;
              no rows selected
              SQL> desc DBVERSION
              Name Null? Type
              MANDATORY NOT NULL NUMBER(10)
              OPTIONAL NOT NULL NUMBER(10)
              SQL> show user
              USER is "ZABBIXPOC"
