Create trigger from HTTP Agent item
  • jvdb
    • Feb 2022
    • 23
    hi,
    i have an http agent item that does an API request to a external server.
    The result is correct that I get from the item:
    {"data":[],"pagination":{"nextCursor":null,"totalItems":0 }}
    Now I want to create a trigger if the following value changes to anything higher than 1
    "totalItems":0
    but I can't seem to figure it out
    • 5002
    Save just the number ($.pagination.totalItems) and then it is easy to make a trigger last(/host/item)>0
    • jvdb
      • Feb 2022
      • 23
      Originally posted by cyber
      https://www.zabbix.com/documentation..._functionality
      The saving just the number, how do I do this?
      • kaiszy
        • Nov 2024
        i think in your item you have
        Type of Information: Numeric (float)
        then goto the Tab preprocessing
        Add step =>
        Parameter: $.pagination.totalItems
        and return it as number. Then you can use the above trigger with that item.
        I hope this helps
        Best regards,
        Kai.
          • 5002
          Exactly! Clicking on that link should give some hints... And reading on preprocessing...
          • jvdb
            • Feb 2022
            • 23
            thanks guys, I just figured it out
