Trigger with different severety base on Host Tags
  • kaiszy
    • Nov 2024
    i try to creaste a template with a trigger, that measures how "slow" a website is. If the reply takes longer that 6 seconds the severity is Disaster. But in only want to show a disaster if the triggered host has the Tag "env=prod". For all other env-Tags i want only a warning.
    Is this possible with a "template base trigger" ?
    Thanks for your help
    Best regards,
    Kai.
    • 5002
    Nope, you can not choose severity based on tags during trigger calculation..
    Tags are added to problem (from all participating components, items, hosts, templates, triggers) during the event creation, they are not part of calculation.
