First time installation on Debian 12
  • bowlsys
    • Mar 2024
    Using Zabbix instructions to install Zabbix I get ERROR 2002 (HY000): Can't connect to local server through socket '/run/mysqld/mysqld.sock' (2) after a successful apt install zabbix-server-mysql zabbix-frontend-php zabbix-apache-conf zabbix-sql-scripts zabbix-agent. I am a complete noob to Zabbix and equally to Linux.
    Any help really appreciated.
  • etfz
    • Apr 2024
    • 21
    I think you need to install MariaDB (MySQL) separately.
    sudo apt install mariadb-server
    • Wojciech_Rawicki
      • Nov 2024
      Hello bowlsys,
      as etfz said, which database you picked up for your setup? It looks like database is down or not installed
      • bowlsys
        • Mar 2024
        Very many thanks for your advice, I have managed to move on considerably.
        I can now open the web page but I am getting an error saying Locale for language "en_US" is not found on the web server.
        Any ideas?
        • fpawlicki
          • Dec 2024
          • 9
          Hi
          Try using locale-gen to generate the locale. Then, restart web server.
          sudo systemctl restart apache2
