Keep trigger of removed item
  • liranp1
    • Feb 2023
    • 13
    i have Cisco switch C9200L and i'm monitoring it with Cisco IOS template.
    there is an option for the interface "Admin Status", when it is disables it removes the interface from the monitoring and zabbix changes the status of the triggers that created to disabled (because the switch does not show the port anymore).
    i use zabbix 7.0.2.
    is there a way to keep trigger enable even if the item not exist?
    or any other way to get alert when port disappear or something like that?
    thank you all
  • Answer selected by liranp1 at 11-12-2024, 14:03.
    ISiroshtan
    • Nov 2019
    • 324
    Hey there
    Based on this template you have a Macro {$NET.IF.IFADMINSTATUS.NOT_MATCHES} set as '^2$'. This what defines admin statuses of interfaces to excluded from discovery. 2 is admin down. You can modify the value on template to '^$' (or any other unmatchable value) to make admin_down interfaces to be set into monitoring. Or you can overwrite it on host level to make only some hosts to set admin_down to monitoring.
    Alternatively you can go into template -> discoveries -> interface discovery and check what is set as "Disable lost resources", good chance it is set to "Immediately", then you can switch it to "Never" or "After X time", so that when interface is set to admin_down it kept enabled for some time.
    Also do note, some of triggers have extra checks in expression for interface to not to be admin_down. So it is possible that even if trigger will remain enabled it will not fire.
    All in all you'd need to test it out to see how to make it fit your requirement.
    • ISiroshtan
      • Nov 2019
      • 324
      Hey there
      • liranp1
        • Feb 2023
        • 13
        hi, thank you so much.
