Set {#SNMPINDEX} range manually
  • zvictorp
    • Feb 2024
    Hi to everyone
    I know that the discovery of network interfaces starts from walking some subtree and collecting the array of SNMP indices.
    Say, if some switch has 28 ports the internal macros {#SNMPINDEX} will consequentially put the values from 1 to 28 to item prototypes.
    Is it possible to use some manually created array of indices in the form of a custom macros, like {#MYCUSTOMINDEX}, and then use it instead of {#SNMPINDEX}?
    The main goal is to get values from a specific port range (24-28, for example), rather than walking through the whole subtree.
    Thank you.
  • Answer selected by zvictorp at 11-12-2024, 14:59.
    zvictorp
    • Feb 2024
    I found that 'TEST' button does not apply filtering.
    Furthermore, I decided to filter by an interface type rather than by the index number.
    And finally, I got the result I wanted.
    Thank you to everyone who paid attention to my post.
    • mrnobody
      • Oct 2024
      • 61
      Hi, you could try use REGEX in LLD filter, like:
      LLD Filtering with Macros - Zabbix Blog
      • zvictorp
        • Feb 2024
        I created the following macros for the test template
        And then set the filter​
        However, it returns a list of all interfaces.
        • Jan_Prusinowski
          • Dec 2024
          Could you paste the filter you created?
          • zvictorp
            • Feb 2024
