Issues with Docker Monitoring in Swarm Mode: Container Name Changes on Restart
  • still_at_work
    • Jul 2023
    • 9
    Hello everyone,
    I’m using Zabbix to monitor my Docker containers, and overall, it works very well. I’ve set up discovery to track containers and monitor their metrics efficiently.
    However, since I started using Docker Swarm, I’ve encountered a challenge. Each time the Docker containers are restarted (due to scaling, updates, or node changes), their names change. For example, a container might be named app_mycontainer.1.xxyz1234 initially, but after a restart, it could be renamed to something like app_mycontainer.1.abcd5678.
    This behavior causes issues in Zabbix:
    • Old container names remain in Zabbix with no metrics (because the containers no longer exist).
    • New container names are treated as entirely new entities, triggering alerts for the "missing" containers.
    I’d like to know if anyone has experienced a similar issue and how you resolved it. Is there a way to handle this dynamically in Zabbix to avoid accumulating non-existent containers and to prevent unnecessary alerts when containers are replaced in Swarm mode?
    Here are the specifics of my setup:
    • Zabbix Version: 6.4.16
    • Docker Setup: Using Docker Swarm
    • Monitoring Template: Docker by Zabbix Agent 2
    • Problem: Container names change on restart due to Docker Swarm's naming convention.
    Thank you in advance for your help!
  • Jan_Prusinowski
    • Dec 2024
    Have you considered using labels instead of Docker container IDs? Labels are static, even if a container changes its name during a restart. Zabbix can be configured to discover and monitor containers based on these labels rather than container names. Would this solution work for you?
    • duarte936
      • Dec 2024
      Hi everyone,
      I'm facing the same issue
      I already tried the following solution: https://medium.com/@archonkulis/zabb...y-b9ffc2b76652, but unfortunately, this template can't even connect to Docker, so I'm stuck at this point.
      I would really appreciate any help!
      Thank you in advance!
      • JJJosph
        • Dec 2024
        Hello everyone,
        I would like to know if there is a solution to this problem?
        • Brambo
          • Jul 2023
          • 250
          I don't use this plugin, but looking at the code of the discovery.go I see that #ID and #NAME are provided as macro's.
          You could try to test this #ID macro in the item key, however as I don't now which values are returned by the macro this also could have unexpected results.
          • toontoet
            • Jul 2025
            I've created a agent2 plugin to get some extra docker swarm stacks and services into zabbix: https://github.com/toontoet/zabbix-a...n-docker-swarm
            • Tristis Oris
              Tristis Oris commented
              Sounds great, but do we need a new template for this?
