Zabbix server is not running: the information displayed may not be current
  • syednizamuddin
    • Mar 2022
    • 14
    Hi All,
    Zabbix version 6.0.28
    An error has been observed on frontend zabbix tool- Zabbix server is not running: the information displayed may not be current
    Zabbix front end server is not connecting to Zabbix backend server
    Frontend server to backend server ping is working
    Services also running fine
    Restarted the servers as well but still issue persisted
    please find below logs details
    177340:20241210:133842.450 ================================
    177340:20241210:133842.450 Please consider attaching a disassembly listing to your bug report.
    177340:20241210:133842.450 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
    177192:20241210:133842.451 One child process died (PID:177340,exitcode/signal:1). Exiting ...
    177192:20241210:133842.454 PROCESS EXIT: 177340
    177193:20241210:133842.454 HA manager has been paused
    177304:20241210:133842.455 cannot read alert manager service request
    177305:20241210:133842.456 cannot read alert manager service request
    177306:20241210:133842.457 cannot read alert manager service request
    177303:20241210:133842.459 cannot read alert manager service request
    177301:20241210:133842.459 cannot read alert manager service request
    177302:20241210:133842.459 cannot read alert manager service request
    177307:20241210:133842.460 cannot read alert manager service request
    177310:20241210:133842.460 cannot read preprocessing service request
    177311:20241210:133842.460 cannot read preprocessing service request
    177314:20241210:133842.461 cannot read LLD manager service request
    zabbix_server [177192]: Error waiting for process with PID 177340: [10] No child processes
    177193:20241210:133842.606 HA manager has been stopped
    177192:20241210:133842.824 syncing trend data...
    177192:20241210:133842.824 syncing trend data done
    177192:20241210:133842.990 Zabbix Server stopped. Zabbix 6.0.29 (revision e8261478baa).
    177535:20241210:133853.211 Starting Zabbix Server. Zabbix 6.0.29 (revision e8261478baa).
    177535:20241210:133853.211 ****** Enabled features ******
    177535:20241210:133853.211 SNMP monitoring: YES
    177535:20241210:133853.211 IPMI monitoring: YES
    177535:20241210:133853.211 Web monitoring: YES
    177535:20241210:133853.211 VMware monitoring: YES
    177535:20241210:133853.211 SMTP authentication: YES
    177535:20241210:133853.211 ODBC: YES
    177535:20241210:133853.211 SSH support: YES
    177535:20241210:133853.211 IPv6 support: YES
    177535:20241210:133853.211 TLS support: YES
    177535:20241210:133853.211 ******************************
    177535:20241210:133853.211 using configuration file: /etc/zabbix/zabbix_server.conf
    177535:20241210:133853.283 current database version (mandatory/optional): 06000000/06000044
    177535:20241210:133853.283 required mandatory version: 06000000
    177536:20241210:133853.344 starting HA manager
    177536:20241210:133853.362 HA manager started in active mode
    177535:20241210:133853.407 server #0 started [main process]
    177537:20241210:133853.408 server #1 started [service manager #1]
    177538:20241210:133853.408 server #2 started [configuration syncer #1]
    177538:20241210:133901.270 slow query: 7.660430 sec, "select i.itemid,i.hostid,i.status,i.type,i.value_typ e,i.key_,i.snmp_oid,i.ipmi_sensor,i.delay,i.trappe r_hosts,i.logtimefmt,i.params,ir.state,i.authtype, i.user name,i.password,i.publickey,i.privatekey,i.flags,i .interfaceid,ir.lastlogsize,ir.mtime,i.history,i.t rends, i.inventory_link,i.valuemapid,i.units,ir.error,i.j mx_endpoint,i.master_itemid,i.timeout,i.url,i.quer y_fiel ds,i.posts,i.status_codes,i.follow_redirects,i.pos t_type,i.http_proxy,i.headers,i.retrieve_mode,i.re quest_ method,i.output_format,i.ssl_cert_file,i.ssl_key_f ile,i.ssl_key_password,i.verify_peer,i.verify_host ,i.all ow_traps,i.templateid,null from items i join item_rtdata ir on i.itemid=ir.itemid"
    177538:20241210:133920.881 slow query: 8.194618 sec, "select triggerid,description,expression,error,priority,ty pe,value,state,lastchange,status,recovery_mode,rec overy_expression,correlation_mode,correlation_tag, opdata,event_name,null,null,null,flags from triggers"
    177656:20241210:133929.323 server #3 started [alert manager #1]
    177657:20241210:133929.323 server #4 started [alerter #1]
    177658:20241210:133929.324 server #5 started [alerter #2]
    177659:20241210:133929.324 server #6 started [alerter #3]
    177660:20241210:133929.324 server #7 started [alerter #4]
    177662:20241210:133929.325 server #9 started [alerter #6]
    177661:20241210:133929.325 server #8 started [alerter #5]
    177663:20241210:133929.325 server #10 started [alerter #7]
    177665:20241210:133929.326 server #12 started [alerter #9]
    177664:20241210:133929.326 server #11 started [alerter #8]
    177666:20241210:133929.326 server #13 started [alerter #10]
    177667:20241210:133929.327 server #14 started [alerter #11]
    177668:20241210:133929.327 server #15 started [alerter #12]
    177669:20241210:133929.328 server #16 started [alerter #13]
    177670:20241210:133929.328 server #17 started [alerter #14]
    177671:20241210:133929.328 server #18 started [alerter #15]
    177672:20241210:133929.329 server #19 started [alerter #16]
    177673:20241210:133929.329 server #20 started [alerter #17]
    177674:20241210:133929.330 server #21 started [alerter #18]
    177682:20241210:133929.333 server #29 started [preprocessing manager #1]
    177684:20241210:133929.333 server #31 started [preprocessing worker #2]
    177683:20241210:133929.334 server #30 started [preprocessing worker #1]
    177685:20241210:133929.334 server #32 started [preprocessing worker #3]
    177686:20241210:133929.334 server #33 started [lld manager #1]
    177687:20241210:133929.335 server #34 started [lld worker #1]
    177693:20241210:133929.335 server #38 started [timer #2]
    177688:20241210:133929.336 server #35 started [lld worker #2]
    177694:20241210:133929.336 server #39 started [timer #3]
    177689:20241210:133929.337 server #36 started [housekeeper #1]
    177696:20241210:133929.337 server #41 started [timer #5]
    177695:20241210:133929.337 server #40 started [timer #4]
    177697:20241210:133929.338 server #42 started [timer #6]
    177698:20241210:133929.338 server #43 started [timer #7]
    177692:20241210:133929.340 server #37 started [timer #1]
    177701:20241210:133929.340 server #46 started [timer #10]
    177700:20241210:133929.340 server #45 started [timer #9]
    177699:20241210:133929.341 server #44 started [timer #8]
    177702:20241210:133929.341 server #47 started [http poller #1]
    177703:20241210:133929.341 server #48 started [discoverer #1]
    177705:20241210:133929.343 server #50 started [history syncer #2]
    177706:20241210:133929.343 server #51 started [history syncer #3]
    177708:20241210:133929.344 server #53 started [history syncer #5]
    177704:20241210:133929.344 server #49 started [history syncer #1]
    177707:20241210:133929.344 server #52 started [history syncer #4]
    177709:20241210:133929.345 server #54 started [history syncer #6]
    177710:20241210:133929.346 server #55 started [history syncer #7]
    177711:20241210:133929.346 server #56 started [history syncer #8]
    177716:20241210:133929.347 server #61 started [escalator #5]
    177713:20241210:133929.347 server #58 started [escalator #2]
    177714:20241210:133929.348 server #59 started [escalator #3]
    177715:20241210:133929.348 server #60 started [escalator #4]
    177728:20241210:133929.353 server #73 started [poller #9]
    177729:20241210:133929.354 server #74 started [poller #10]
    177730:20241210:133929.355 server #75 started [unreachable poller #1]
    177726:20241210:133929.355 server #71 started [poller #7]
    177725:20241210:133929.356 server #70 started [poller #6]
    177727:20241210:133929.356 server #72 started [poller #8]
    177722:20241210:133929.357 server #67 started [poller #3]
    177731:20241210:133929.357 server #76 started [trapper #1]
    177732:20241210:133929.358 server #77 started [trapper #2]
    177741:20241210:133929.359 server #86 started [trapper #11]
    177734:20241210:133929.361 server #79 started [trapper #4]
    177735:20241210:133929.361 server #80 started [trapper #5]
    177736:20241210:133929.362 server #81 started [trapper #6]
    177737:20241210:133929.362 server #82 started [trapper #7]
    177738:20241210:133929.363 server #83 started [trapper #8]
    177739:20241210:133929.364 server #84 started [trapper #9]
    177740:20241210:133929.364 server #85 started [trapper #10]
    177733:20241210:133929.365 server #78 started [trapper #3]
    177748:20241210:133929.365 server #93 started [trapper #18]
    177742:20241210:133929.366 server #87 started [trapper #12]
    177761:20241210:133929.367 server #106 started [trapper #31]
    177744:20241210:133929.368 server #89 started [trapper #14]
    177745:20241210:133929.368 server #90 started [trapper #15]
    177746:20241210:133929.369 server #91 started [trapper #16]
    177747:20241210:133929.370 server #92 started [trapper #17]
    177743:20241210:133929.370 server #88 started [trapper #13]
    177762:20241210:133929.370 server #107 started [trapper #32]
    177778:20241210:133929.371 server #123 started [trapper #48]
    177763:20241210:133929.372 server #108 started [trapper #33]
    177764:20241210:133929.373 server #109 started [trapper #34]
    177765:20241210:133929.373 server #110 started [trapper #35]
    177766:20241210:133929.374 server #111 started [trapper #36]
    177779:20241210:133929.375 server #124 started [trapper #49]
    177767:20241210:133929.375 server #112 started [trapper #37]
    177768:20241210:133929.376 server #113 started [trapper #38]
    177790:20241210:133929.377 server #135 started [trapper #60]
    177751:20241210:133929.378 server #96 started [trapper #21]
    177794:20241210:133929.378 server #139 started [trapper #64]
    177754:20241210:133929.379 server #99 started [trapper #24]
    177771:20241210:133929.382 server #116 started [trapper #41]
    177798:20241210:133929.382 server #143 started [trapper #68]
    177770:20241210:133929.383 server #115 started [trapper #40]
    177772:20241210:133929.383 server #117 started [trapper #42]
    177800:20241210:133929.384 server #145 started [trapper #70]
    177750:20241210:133929.385 server #95 started [trapper #20]
    177749:20241210:133929.385 server #94 started [trapper #19]
    177752:20241210:133929.386 server #97 started [trapper #22]
    177753:20241210:133929.387 server #98 started [trapper #23]
    177796:20241210:133929.387 server #141 started [trapper #66]
    177769:20241210:133929.388 server #114 started [trapper #39]
    177797:20241210:133929.389 server #142 started [trapper #67]
    177786:20241210:133929.389 server #131 started [trapper #56]
    177787:20241210:133929.390 server #132 started [trapper #57]
    177793:20241210:133929.391 server #138 started [trapper #63]
    177807:20241210:133929.391 server #152 started [trapper #77]
    177760:20241210:133929.392 server #105 started [trapper #30]
    177795:20241210:133929.393 server #140 started [trapper #65]
    177788:20241210:133929.394 server #133 started [trapper #58]
    177826:20241210:133929.394 server #171 started [trapper #96]
    177785:20241210:133929.395 server #130 started [trapper #55]
    177789:20241210:133929.395 server #134 started [trapper #59]
    177757:20241210:133929.396 server #102 started [trapper #27]
    177792:20241210:133929.397 server #137 started [trapper #62]
    177791:20241210:133929.397 server #136 started [trapper #61]
    177837:20241210:133929.398 server #182 started [history poller #5]
    177775:20241210:133929.399 server #120 started [trapper #45]
    177776:20241210:133929.399 server #121 started [trapper #46]
    177777:20241210:133929.400 server #122 started [trapper #47]
    177824:20241210:133929.400 server #169 started [trapper #94]
    177756:20241210:133929.402 server #101 started [trapper #26]
    177759:20241210:133929.402 server #104 started [trapper #29]
    177799:20241210:133929.402 server #144 started [trapper #69]
    177784:20241210:133929.403 server #129 started [trapper #54]
    177801:20241210:133929.404 server #146 started [trapper #71]
    177802:20241210:133929.404 server #147 started [trapper #72]
    177803:20241210:133929.405 server #148 started [trapper #73]
    177804:20241210:133929.405 server #149 started [trapper #74]
    177780:20241210:133929.406 server #125 started [trapper #50]
    177781:20241210:133929.406 server #126 started [trapper #51]
    177782:20241210:133929.406 server #127 started [trapper #52]
    177783:20241210:133929.407 server #128 started [trapper #53]
    177805:20241210:133929.407 server #150 started [trapper #75]
    177806:20241210:133929.408 server #151 started [trapper #76]
    177755:20241210:133929.408 server #100 started [trapper #25]
    177808:20241210:133929.408 server #153 started [trapper #78]
    177809:20241210:133929.408 server #154 started [trapper #79]
    177810:20241210:133929.409 server #155 started [trapper #80]
    177821:20241210:133929.409 server #166 started [trapper #91]
    177820:20241210:133929.410 server #165 started [trapper #90]
    177812:20241210:133929.410 server #157 started [trapper #82]
    177825:20241210:133929.411 server #170 started [trapper #95]
    177816:20241210:133929.412 server #161 started [trapper #86]
    177813:20241210:133929.412 server #158 started [trapper #83]
    177811:20241210:133929.413 server #156 started [trapper #81]
    177814:20241210:133929.413 server #159 started [trapper #84]
    177827:20241210:133929.413 server #172 started [trapper #97]
    177758:20241210:133929.414 server #103 started [trapper #28]
    177828:20241210:133929.415 server #173 started [trapper #98]
    177815:20241210:133929.415 server #160 started [trapper #85]
    177829:20241210:133929.415 server #174 started [trapper #99]
    177818:20241210:133929.416 server #163 started [trapper #88]
    177817:20241210:133929.417 server #162 started [trapper #87]
    177819:20241210:133929.418 server #164 started [trapper #89]
    177830:20241210:133929.418 server #175 started [trapper #100]
    177831:20241210:133929.418 server #176 started [icmp pinger #1]
    177832:20241210:133929.419 server #177 started [alert syncer #1]
    177823:20241210:133929.419 server #168 started [trapper #93]
    177822:20241210:133929.419 server #167 started [trapper #92]
    177833:20241210:133929.420 server #178 started [history poller #1]
    177834:20241210:133929.420 server #179 started [history poller #2]
    177835:20241210:133929.421 server #180 started [history poller #3]
    177836:20241210:133929.421 server #181 started [history poller #4]
    177774:20241210:133929.422 server #119 started [trapper #44]
    177838:20241210:133929.422 server #183 started [availability manager #1]
    177773:20241210:133929.422 server #118 started [trapper #43]
    177839:20241210:133929.422 server #184 started [report manager #1]
    177850:20241210:133929.423 server #195 started [trigger housekeeper #1]
    177851:20241210:133929.423 server #196 started [odbc poller #1]
    177739:20241210:133929.447 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177739:20241210:133929.450 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177739:20241210:133929.451 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177732:20241210:133929.451 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177739:20241210:133929.452 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177732:20241210:133929.452 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177732:20241210:133929.453 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177732:20241210:133929.454 failed to accept an incoming connection: from IP address0: unspecified certificate verification error: TLS handshake set result code to 5:
    177732:20241210:133929.454 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177732:20241210:133929.455 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177732:20241210:133929.456 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177732:20241210:133929.457 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177739:20241210:133929.457 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177739:20241210:133929.458 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177732:20241210:133929.458 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
    177840:20241210:133929.499 server #185 started [report writer #1]
    177841:20241210:133929.500 server #186 started [report writer #2]
    177842:20241210:133929.501 server #187 started [report writer #3]
    177844:20241210:133929.501 server #189 started [report writer #5]
    177843:20241210:133929.501 server #188 started [report writer #4]
    177845:20241210:133929.502 server #190 started [report writer #6]
    177846:20241210:133929.502 server #191 started [report writer #7]
    177847:20241210:133929.502 server #192 started [report writer #8]
    177849:20241210:133929.502 server #194 started [report writer #10]
    177848:20241210:133929.503 server #193 started [report writer #9]
    177716:20241210:133929.712 Got signal [signal:11(SIGSEGV),reason:1,refaddrnil)]. Crashing ...
    177716:20241210:133929.712 ====== Fatal information: ======
    177716:20241210:133929.712 Program counter: 0x7f72a3923915
    177716:20241210:133929.712 === Registers: ===
    177716:20241210:133929.712 r8 = 1 = 1 = 1
    177716:20241210:133929.712 r9 = 675898f1 = 1733859569 = 1733859569
    177716:20241210:133929.713 r10 = 7ffcef1b5080 = 140724320030848 = 140724320030848
    177716:20241210:133929.713 r11 = 522916 = 5384470 = 5384470
    177716:20241210:133929.713 r12 = 55cc8240e4a0 = 94336846980256 = 94336846980256
    177716:20241210:133929.713 r13 = 255 = 597 = 597
    177716:20241210:133929.713 r14 = 55cc8306a230 = 94336859939376 = 94336859939376
    177716:20241210:133929.713 r15 = 7ffcef021c60 = 140724318379104 = 140724318379104
    177716:20241210:133929.713 rdi = 0 = 0 = 0
    177716:20241210:133929.713 rsi = 255 = 597 = 597
    177716:20241210:133929.713 rbp = 0 = 0 = 0
    177716:20241210:133929.713 rbx = 9 = 9 = 9
    177716:20241210:133929.714 rdx = 0 = 0 = 0
    177716:20241210:133929.715 rax = 55cc822b8f46 = 94336845582150 = 94336845582150
    177716:20241210:133929.715 rcx = 0 = 0 = 0
    177716:20241210:133929.715 rsp = 7ffcef01aad8 = 140724318350040 = 140724318350040
    177716:20241210:133929.715 rip = 7f72a3923915 = 140130347268373 = 140130347268373
    177716:20241210:133929.715 efl = 10283 = 66179 = 66179
    177716:20241210:133929.715 csgsfs = 2b000000000033 = 12103423998558259 = 12103423998558259
    177716:20241210:133929.715 err = 4 = 4 = 4
    177716:20241210:133929.715 trapno = e = 14 = 14
    177716:20241210:133929.715 oldmask = 0 = 0 = 0
    177716:20241210:133929.715 cr2 = 0 = 0 = 0
    177716:20241210:133929.716 === Backtrace: ===
    177716:20241210:133929.717 23: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](zbx_backtrace+0x51) [0x55cc822e5cf1]
    177716:20241210:133929.722 22: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](zbx_log_fatal_info+0x475) [0x55cc822e6285]
    177716:20241210:133929.722 21: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0x1ea79a) [0x55cc822e679a]
    177716:20241210:133929.722 20: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f72a4061420]
    177716:20241210:133929.722 19: /lib/x86_64-linux-gnu/libc.so.6(+0x188915) [0x7f72a3923915]
    177716:20241210:133929.722 18: /lib/x86_64-linux-gnu/libc.so.6(__strdup+0x13) [0x7f72a383a383]
    177716:20241210:133929.723 17: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](zbx_strdup2+0x3b) [0x55cc8230506b]
    177716:20241210:133929.723 16: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0x1bcf62) [0x55cc822b8f62]
    177716:20241210:133929.723 15: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](DBget_trigger_value+0x57) [0x55cc822bd457]
    177716:20241210:133929.723 14: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0x1cb360) [0x55cc822c7360]
    177716:20241210:133929.723 13: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](substitute_simple_macros+0x39) [0x55cc822cb839]
    177716:20241210:133929.723 12: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0xba249) [0x55cc821b6249]
    177716:20241210:133929.723 11: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0xba579) [0x55cc821b6579]
    177716:20241210:133929.723 10: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0xbcbe8) [0x55cc821b8be8]
    177716:20241210:133929.724 9: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0xbf6f2) [0x55cc821bb6f2]
    177716:20241210:133929.724 8: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0xc0fe4) [0x55cc821bcfe4]
    177716:20241210:133929.724 7: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](escalator_thread+0x1e0) [0x55cc821bd950]
    177716:20241210:133929.724 6: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](zbx_thread_start+0x24) [0x55cc822e8394]
    177716:20241210:133929.724 5: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0x75a58) [0x55cc82171a58]
    177716:20241210:133929.724 4: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](MAIN_ZABBIX_ENTRY+0xa81) [0x55cc82172a51]
    177716:20241210:133929.724 3: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](daemon_start+0x16d) [0x55cc822e58ed]
    177716:20241210:133929.724 2: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](main+0x4b7) [0x55cc82169997]
    177716:20241210:133929.725 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7f72a37bf083]
    177716:20241210:133929.725 0: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](_start+0x2e) [0x55cc82170a1e]
    177716:20241210:133929.726 === Memory map: ===
    177716:20241210:133929.727 55cc820fc000-55cc82163000 r--p 00000000 fd:00 920166 /usr/sbin/zabbix_server
    177716:20241210:133929.727 55cc82163000-55cc823d3000 r-xp 00067000 fd:00 920166 /usr/sbin/zabbix_server
    177716:20241210:133929.740 7f72a0e68000-7f72a0e6a000 rw-p 00000000 00:00 0
    177716:20241210:133929.740 7f72a0e6a000-7f72a0e7a000 r--p 00000000 fd:00 922491 /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0
    177716:20241210:133929.740 7f72a0e7a000-7f72a0ea3000 r-xp 00010000 fd:00 922491 /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0
    177716:20241210:133929.740 7f72a0ea3000-7f72a0eb3000 r--p 00039000 fd:00 922491 /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0
    177716:20241210:133929.740 7f72a0eb3000-7f72a0eb6000 r--p 00048000 fd:00 922491 /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0
    177716:20241210:133929.740 7f72a0eb6000-7f72a0eb7000 rw-p 0004b000 fd:00 922491 /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0
    177716:20241210:133929.740 7f72a0eb7000-7f72a0eb8000 rw-p 00000000 00:00 0
    177716:20241210:133929.741 7f72a0eb8000-7f72a0ebb000 r--p 00000000 fd:00 922485 /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0
    177716:20241210:133929.741 7f72a0ebb000-7f72a0ec4000 r-xp 00003000 fd:00 922485 /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0
    177716:20241210:133929.741 7f72a0ec4000-7f72a0ec8000 r--p 0000c000 fd:00 922485 /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0
    177716:20241210:133929.741 7f72a0ec8000-7f72a0ec9000 r--p 0000f000 fd:00 922485 /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0
    177716:20241210:133929.741 7f72a0ec9000-7f72a0eca000 rw-p 00010000 fd:00 922485 /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0
    177716:20241210:133929.741 7f72a0eca000-7f72a0ecb000 r--p 00000000 fd:00 922489 /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0
    177716:20241210:133929.741 7f72a0ecb000-7f72a0ecd000 r-xp 00001000 fd:00 922489 /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0
    177716:20241210:133929.742 7f72a0ecd000-7f72a0ef2000 r--p 00003000 fd:00 922489 /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0
    177716:20241210:133929.742 7f72a0ef2000-7f72a0ef3000 r--p 00027000 fd:00 922489 /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0
    177716:20241210:133929.742 7f72a0ef3000-7f72a0ef4000 rw-p 00028000 fd:00 922489 /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0
    177716:20241210:133929.742 7f72a0ef4000-7f72a0ef6000 r--p 00000000 fd:00 920495 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    177716:20241210:133929.742 7f72a0ef6000-7f72a0ef8000 r-xp 00002000 fd:00 920495 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    177716:20241210:133929.742 7f72a0ef8000-7f72a0ef9000 r--p 00004000 fd:00 920495 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    177716:20241210:133929.742 7f72a0ef9000-7f72a0efa000 r--p 00004000 fd:00 920495 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    177716:20241210:133929.742 7f72a0efa000-7f72a0efb000 rw-p 00005000 fd:00 920495 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    177716:20241210:133929.742 7f72a0efb000-7f72a0efc000 r--p 00000000 fd:00 924048 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    177716:20241210:133929.743 7f72a0efc000-7f72a0efd000 r-xp 00001000 fd:00 924048 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    177716:20241210:133929.743 7f72a0efd000-7f72a0f1c000 r--p 00002000 fd:00 924048 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    177716:20241210:133929.743 7f72a0f1c000-7f72a0f1d000 r--p 00020000 fd:00 924048 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    177716:20241210:133929.743 7f72a0f1d000-7f72a0f1e000 rw-p 00021000 fd:00 924048 /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    177716:20241210:133929.743 7f72a0f1e000-7f72a0f20000 rw-p 00000000 00:00 0
    177716:20241210:133929.743 7f72a0f20000-7f72a0f2a000 r--p 00000000 fd:00 923520 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    177716:20241210:133929.743 7f72a0f2a000-7f72a0f8a000 r-xp 0000a000 fd:00 923520 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    177716:20241210:133929.743 7f72a0f8a000-7f72a0fa1000 r--p 0006a000 fd:00 923520 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    177716:20241210:133929.744 7f72a0fa1000-7f72a0fa2000 ---p 00081000 fd:00 923520 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    177716:20241210:133929.744 7f72a0fa2000-7f72a0fa3000 r--p 00081000 fd:00 923520 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    177716:20241210:133929.744 7f72a0fa3000-7f72a0fa4000 rw-p 00082000 fd:00 923520 /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    177716:20241210:133929.744 7f72a0fa4000-7f72a0fab000 r--p 00000000 fd:00 923636 /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    177716:20241210:133929.744 7f72a0fab000-7f72a0fbb000 r-xp 00007000 fd:00 923636 /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    177716:20241210:133929.744 7f72a0fbb000-7f72a0fd9000 r--p 00017000 fd:00 923636 /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    177716:20241210:133929.744 7f72a0fd9000-7f72a0fda000 r--p 00034000 fd:00 923636 /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    177716:20241210:133929.744 7f72a0fda000-7f72a0fdb000 rw-p 00035000 fd:00 923636 /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    177716:20241210:133929.744 7f72a0fdb000-7f72a0fe4000 r--p 00000000 fd:00 923568 /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    177716:20241210:133929.745 7f72a0fe4000-7f72a1002000 r-xp 00009000 fd:00 923568 /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    177716:20241210:133929.745 7f72a1002000-7f72a1012000 r--p 00027000 fd:00 923568 /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    177716:20241210:133929.745 7f72a1012000-7f72a1014000 r--p 00036000 fd:00 923568 /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    177716:20241210:133929.745 7f72a1014000-7f72a1015000 rw-p 00038000 fd:00 923568 /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    177716:20241210:133929.745 7f72a1015000-7f72a1018000 r--p 00000000 fd:00 924251 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    177716:20241210:133929.745 7f72a1018000-7f72a1024000 r-xp 00003000 fd:00 924251 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    177716:20241210:133929.745 7f72a1024000-7f72a1028000 r--p 0000f000 fd:00 924251 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    177716:20241210:133929.745 7f72a1028000-7f72a1029000 ---p 00013000 fd:00 924251 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    177716:20241210:133929.745 7f72a1029000-7f72a102a000 r--p 00013000 fd:00 924251 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    177716:20241210:133929.745 7f72a102a000-7f72a102b000 rw-p 00014000 fd:00 924251 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    177716:20241210:133929.746 7f72a102b000-7f72a103b000 r--p 00000000 fd:00 924266 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    177716:20241210:133929.746 7f72a103b000-7f72a1071000 r-xp 00010000 fd:00 924266 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    177716:20241210:133929.746 7f72a1071000-7f72a11a8000 r--p 00046000 fd:00 924266 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    177716:20241210:133929.746 7f72a11a8000-7f72a11a9000 ---p 0017d000 fd:00 924266 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    177716:20241210:133929.746 7f72a11a9000-7f72a11ac000 r--p 0017d000 fd:00 924266 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    177716:20241210:133929.747 7f72a11ac000-7f72a11ad000 rw-p 00180000 fd:00 924266 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    177716:20241210:133929.747 7f72a11ad000-7f72a11af000 rw-p 00000000 00:00 0
    177716:20241210:133929.747 7f72a11af000-7f72a11da000 r--p 00000000 fd:00 924197 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    177716:20241210:133929.747 7f72a11da000-7f72a1274000 r-xp 0002b000 fd:00 924197 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    177716:20241210:133929.747 7f72a1274000-7f72a12d0000 r--p 000c5000 fd:00 924197 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    177716:20241210:133929.747 7f72a12d0000-7f72a12db000 r--p 00120000 fd:00 924197 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    177716:20241210:133929.747 7f72a12db000-7f72a12e5000 rw-p 0012b000 fd:00 924197 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    177716:20241210:133929.747 7f72a12e5000-7f72a12ea000 r--p 00000000 fd:00 918238 /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    177716:20241210:133929.747 7f72a12ea000-7f72a12f7000 r-xp 00005000 fd:00 918238 /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    177716:20241210:133929.748 7f72a12f7000-7f72a12fb000 r--p 00012000 fd:00 918238 /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    177716:20241210:133929.748 7f72a12fb000-7f72a12fc000 ---p 00016000 fd:00 918238 /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    177716:20241210:133929.748 7f72a12fc000-7f72a12fd000 r--p 00016000 fd:00 918238 /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    177716:20241210:133929.748 7f72a12fd000-7f72a12fe000 rw-p 00017000 fd:00 918238 /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    177716:20241210:133929.748 7f72a12fe000-7f72a1305000 r--p 00000000 fd:00 922487 /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0
    177716:20241210:133929.748 7f72a1305000-7f72a1324000 r-xp 00007000 fd:00 922487 /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0
    177716:20241210:133929.748 7f72a1324000-7f72a1332000 r--p 00026000 fd:00 922487 /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0
    177716:20241210:133929.748 7f72a1332000-7f72a1334000 r--p 00033000 fd:00 922487 /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0
    177716:20241210:133929.748 7f72a1334000-7f72a1335000 rw-p 00035000 fd:00 922487 /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0
    177716:20241210:133929.749 7f72a1335000-7f72a1336000 rw-p 00000000 00:00 0
    177716:20241210:133929.749 7f72a1336000-7f72a1350000 r--p 00000000 fd:00 920922 /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    177716:20241210:133929.749 7f72a1350000-7f72a13ba000 r-xp 0001a000 fd:00 920922 /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    177716:20241210:133929.749 7f72a13ba000-7f72a13d7000 r--p 00084000 fd:00 920922 /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    177716:20241210:133929.749 7f72a13d7000-7f72a13d8000 ---p 000a1000 fd:00 920922 /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    177716:20241210:133929.749 7f72a13d8000-7f72a13d9000 r--p 000a1000 fd:00 920922 /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    177716:20241210:133929.749 7f72a13d9000-7f72a13dc000 rw-p 000a2000 fd:00 920922 /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    177716:20241210:133929.749 7f72a13dc000-7f72a13f7000 r--p 00000000 fd:00 922493 /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0
    177716:20241210:133929.749 7f72a13f7000-7f72a1448000 r-xp 0001b000 fd:00 922493 /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0
    177716:20241210:133929.749 7f72a1448000-7f72a1468000 r--p 0006c000 fd:00 922493 /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0
    177716:20241210:133929.750 7f72a1468000-7f72a146c000 r--p 0008b000 fd:00 922493 /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0
    177716:20241210:133929.750 7f72a146c000-7f72a146e000 rw-p 0008f000 fd:00 922493 /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0
    177716:20241210:133929.750 7f72a146e000-7f72a146f000 rw-p 00000000 00:00 0
    177716:20241210:133929.750 7f72a146f000-7f72a1472000 r--p 00000000 fd:00 922495 /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    177716:20241210:133929.750 7f72a1472000-7f72a1476000 r-xp 00003000 fd:00 922495 /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    177716:20241210:133929.750 7f72a1476000-7f72a1478000 r--p 00007000 fd:00 922495 /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    177716:20241210:133929.750 7f72a1478000-7f72a1479000 ---p 00009000 fd:00 922495 /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    177716:20241210:133929.750 7f72a1479000-7f72a147a000 r--p 00009000 fd:00 922495 /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    177716:20241210:133929.750 7f72a147a000-7f72a147b000 rw-p 0000a000 fd:00 922495 /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    177716:20241210:133929.750 7f72a147b000-7f72a147d000 rw-p 00000000 00:00 0
    177716:20241210:133929.750 7f72a147d000-7f72a1480000 r--p 00000000 fd:00 917558 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    177716:20241210:133929.753 7f72a1480000-7f72a1492000 r-xp 00003000 fd:00 917558 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    177716:20241210:133929.753 7f72a1492000-7f72a1496000 r--p 00015000 fd:00 917558 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    177716:20241210:133929.753 7f72a1496000-7f72a1497000 r--p 00018000 fd:00 917558 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    177716:20241210:133929.753 7f72a1497000-7f72a1498000 rw-p 00019000 fd:00 917558 /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    177716:20241210:133929.753 7f72a1498000-7f72a152e000 r--p 00000000 fd:00 917556 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    177716:20241210:133929.754 7f72a152e000-7f72a161f000 r-xp 00096000 fd:00 917556 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    177716:20241210:133929.754 7f72a161f000-7f72a1668000 r--p 00187000 fd:00 917556 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    177716:20241210:133929.754 7f72a1668000-7f72a1669000 ---p 001d0000 fd:00 917556 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    177716:20241210:133929.754 7f72a1669000-7f72a1674000 r--p 001d0000 fd:00 917556 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    177716:20241210:133929.754 7f72a1674000-7f72a1677000 rw-p 001db000 fd:00 917556 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    177716:20241210:133929.788 7f72a4649000-7f72a464a000 rw-p 00000000 00:00 0
    177716:20241210:133929.788 7ffcef006000-7ffcef027000 rw-p 00000000 00:00 0 [stack]
    177716:20241210:133929.788 7ffcef1b5000-7ffcef1b8000 r--p 00000000 00:00 0 [vvar]
    177716:20241210:133929.789 7ffcef1b8000-7ffcef1b9000 r-xp 00000000 00:00 0 [vdso]
    177716:20241210:133929.789 ffffffffff600000-ffffffffff601000 --xp 00000000 00:00 0 [vsyscall]
    177716:20241210:133929.789 ================================
    177716:20241210:133929.789 Please consider attaching a disassembly listing to your bug report.
    177716:20241210:133929.789 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
    177535:20241210:133929.791 One child process died (PID:177716,exitcode/signal:1). Exiting ...
    177535:20241210:133930.346 PROCESS EXIT: 177716
    177536:20241210:133930.347 HA manager has been paused
    zabbix_server [177535]: Error waiting for process with PID 177716: [10] No child processes
    177536:20241210:133930.515 HA manager has been stopped
    177535:20241210:133930.730 syncing history data...
    177535:20241210:133930.741 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(290017, 1733853518, 15802223) already exists.
    177535:20241210:133930.965 skipped 889 duplicates
    177535:20241210:133930.973 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(392924, 1733853524, 136151676) already exists.
    177535:20241210:133931.109 skipped 848 duplicates
    177535:20241210:133931.120 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(289712, 1733853532, 339378891) already exists.
    177535:20241210:133931.259 skipped 874 duplicates
    177535:20241210:133931.268 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(285861, 1733853534, 343369532) already exists.
    177535:20241210:133931.398 skipped 866 duplicates
    177535:20241210:133931.407 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(1240438, 1733853538, 623704722) already exists.
    177535:20241210:133931.522 skipped 907 duplicates
    177535:20241210:133931.528 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(285954, 1733853540, 353069677) already exists.
    177535:20241210:133931.665 skipped 872 duplicates
    177535:20241210:133931.674 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(119209, 1733853544, 355148521) already exists.
    177535:20241210:133931.781 skipped 771 duplicates
    177535:20241210:133931.787 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(127386, 1733853551, 360281693) already exists.
    177535:20241210:133931.903 skipped 766 duplicates
    177535:20241210:133931.910 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(127429, 1733853553, 361182349) already exists.
    177535:20241210:133932.017 skipped 764 duplicates
    177535:20241210:133932.024 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(119327, 1733853557, 362929045) already exists.
    177535:20241210:133932.149 skipped 838 duplicates
    177535:20241210:133932.154 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(441614, 1733853559, 34815048) already exists.
    177535:20241210:133932.263 skipped 741 duplicates
    177535:20241210:133932.268 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3708_2238_history_pkey"
    DETAIL: Key (itemid, clock, ns)=(441627, 1733853559, 78579263) already exists.
    177535:20241210:133932.326 skipped 450 duplicates
    177535:20241210:133932.329 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3707_2237_history_log_pkey"
    DETAIL: Key (itemid, clock, ns)=(9108506, 1733853540, 335930400) already exists.
    177535:20241210:133932.339 skipped 51 duplicates
    177535:20241210:133932.341 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3707_2237_history_log_pkey"
    DETAIL: Key (itemid, clock, ns)=(9108506, 1733853540, 335932100) already exists.
    177535:20241210:133932.344 skipped 7 duplicates
    177535:20241210:133932.346 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3707_2237_history_log_pkey"
    DETAIL: Key (itemid, clock, ns)=(9108506, 1733853540, 335935800) already exists.
    177535:20241210:133932.348 skipped 6 duplicates
    177535:20241210:133932.351 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3707_2237_history_log_pkey"
    DETAIL: Key (itemid, clock, ns)=(9108506, 1733853540, 335937200) already exists.
    177535:20241210:133932.352 skipped 1 duplicates
    177535:20241210:133932.354 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3707_2237_history_log_pkey"
    DETAIL: Key (itemid, clock, ns)=(9108506, 1733853540, 335938600) already exists.
    177535:20241210:133932.355 skipped 1 duplicates
    177535:20241210:133932.358 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3707_2237_history_log_pkey"
    DETAIL: Key (itemid, clock, ns)=(9108506, 1733853540, 335941600) already exists.
    177535:20241210:133932.359 skipped 1 duplicates
    177535:20241210:133932.361 syncing history data... 100.000000%
    177535:20241210:133932.361 syncing history data done
    177535:20241210:133932.361 syncing trend data...
    177535:20241210:133932.361 syncing trend data done
    177535:20241210:133932.530 Zabbix Server stopped. Zabbix 6.0.29 (revision e8261478baa).
    177939:20241210:133942.710 Starting Zabbix Server. Zabbix 6.0.29 (revision e8261478baa).
    177939:20241210:133942.711 ****** Enabled features ******
    177939:20241210:133942.711 SNMP monitoring: YES
    177939:20241210:133942.711 IPMI monitoring: YES
    177939:20241210:133942.711 Web monitoring: YES
    177939:20241210:133942.711 VMware monitoring: YES
    177939:20241210:133942.712 SMTP authentication: YES
    177939:20241210:133942.712 ODBC: YES
    177939:20241210:133942.712 SSH support: YES
    177939:20241210:133942.712 IPv6 support: YES
    177939:20241210:133942.712 TLS support: YES
    177939:20241210:133942.712 ******************************
  • syednizamuddin
    • Mar 2022
    • 14
    Additional inputs- We verified DB details on both files its looks same as well ( zabbix_server.conf file and zabbix.conf.php file)
      Your server crashes (escalator #5 process died), in some reason. Nothing to do with DB credentials
      But what makes that process die, that is to be discovered....
      • syednizamuddin
        syednizamuddin commented
        We appreciate your quick reply.
        We were unable to find any errors pertaining to the escalator #5 process died here. If you could provide further information, that would be greatly appreciated.
        Please see the log file details below.
        sudo tail -f /var/log/zabbix/zabbix_server.log | grep -i escalator
        3082649:20241213:085256.681 server #57 started [escalator #1]
        3082650:20241213:085256.681 server #58 started [escalator #2]
        3082652:20241213:085256.683 server #60 started [escalator #4]
        3082651:20241213:085256.683 server #59 started [escalator #3]
        3082653:20241213:085256.683 server #61 started [escalator #5]
        3082653:20241213:085258.437 23: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](zbx_backtrace+0x51) [0x5624667a3cf1]
        3082653:20241213:085258.437 22: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](zbx_log_fatal_info+0x475) [0x5624667a4285]
        3082653:20241213:085258.437 21: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0x1ea79a) [0x5624667a479a]
        3082653:20241213:085258.437 17: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](zbx_strdup2+0x3b) [0x5624667c306b]
        3082653:20241213:085258.437 16: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0x1bcf62) [0x562466776f62]
        3082653:20241213:085258.437 15: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](DBget_trigger_value+0x57) [0x56246677b457]
        3082653:20241213:085258.437 14: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0x1cb360) [0x562466785360]
        3082653:20241213:085258.438 13: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](substitute_simple_macros+0x39) [0x562466789839]
        3082653:20241213:085258.438 12: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0xba249) [0x562466674249]
        3082653:20241213:085258.438 11: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0xba579) [0x562466674579]
        3082653:20241213:085258.438 10: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0xbcbe8) [0x562466676be8]
        3082653:20241213:085258.438 9: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0xbf6f2) [0x5624666796f2]
        3082653:20241213:085258.438 8: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0xc0fe4) [0x56246667afe4]
        3082653:20241213:085258.438 7: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](escalator_thread+0x1e0) [0x56246667b950]
        3082653:20241213:085258.438 6: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](zbx_thread_start+0x24) [0x5624667a6394]
        3082653:20241213:085258.438 5: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](+0x75a58) [0x56246662fa58]
        3082653:20241213:085258.438 4: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](MAIN_ZABBIX_ENTRY+0xa81) [0x562466630a51]
        3082653:20241213:085258.438 3: /usr/sbin/zabbix_server: escalator #5 [processed 0 escalations in 0.000000 sec, processing escalations](daemon_start+0x16d) [
        sudo tail -f /var/log/zabbix/zabbix_server.log | grep -i error
        3075029:20241213:084638.656 slow query: 8.921760 sec, "select i.itemid,i.hostid,i.status,i.type,i.value_type,i.k ey_,i.snmp_oid,i.ipmi_sensor,i.delay,i.trapper_hos ts,i.logtimefmt,i.params,ir.state,i.authtype,i.use rname,i.password,i.publickey,i.privatekey,i.flags, i.interfaceid,ir.lastlogsize,ir.mtime,i.history,i. trends,i.inventory_link,i.valuemapid,i.units,ir.er ror,i.jmx_endpoint,i.master_itemid,i.timeout,i.url ,i.query_fields,i.posts,i.status_codes,i.follow_re directs,i.post_type,i.http_proxy,i.headers,i.retri eve_mode,i.request_method,i.output_format,i.ssl_ce rt_file,i.ssl_key_file,i.ssl_key_password,i.verify _peer,i.verify_host,i.allow_traps,i.templateid,nul l from items i join item_rtdata ir on i.itemid=ir.itemid"
        3075029:20241213:084657.969 slow query: 8.316027 sec, "select triggerid,description,expression,error,priority,ty pe,value,state,lastchange,status,recovery_mode,rec overy_expression,correlation_mode,correlation_tag, opdata,event_name,null,null,null,flags from triggers"
        3075175:20241213:084706.549 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
        3075175:20241213:084706.550 failed to accept an incoming connection: from IP address: unspecified certificate verification error: TLS handshake set result code to 5:
        zabbix_server [3075026]: Error waiting for process with PID 3075159: [10] No child processes
        3075026:20241213:084708.900 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3717_2242_history_pkey"
        3075026:20241213:084709.127 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3738_2253_history_pkey"
        3075026:20241213:084709.348 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3738_2253_history_pkey"
        3075026:20241213:084709.569 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3738_2253_history_pkey"
        3075026:20241213:084709.786 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3738_2253_history_pkey"
        3075026:20241213:084710.015 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3738_2253_history_pkey"
        3075026:20241213:084710.243 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3727_2247_history_pkey"
        3075026:20241213:084710.489 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3727_2247_history_pkey"
        3075026:20241213:084710.723 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3727_2247_history_pkey"
        3075026:20241213:084710.997 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3738_2253_history_pkey"
        3075026:20241213:084711.263 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3738_2253_history_pkey"
        3075026:20241213:084711.479 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3738_2253_history_pkey"
        3075026:20241213:084711.702 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3738_2253_history_pkey"
        3075026:20241213:084711.826 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3738_2253_history_pkey"
        3075026:20241213:084712.074 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3738_2253_history_pkey"
        3075026:20241213:084712.684 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3727_2247_history_pkey"
        3075026:20241213:084713.369 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3727_2247_history_pkey"
        3075026:20241213:084713.969 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3727_2247_history_pkey"
        3075026:20241213:084714.668 [Z3008] query failed due to primary key constraint: [0] PGRES_FATAL_ERROR:ERROR: duplicate key value violates unique constraint "3727_2247_history_pkey"
    • syednizamuddin
      • Mar 2022
      • 14
      • saquib akhtar
        • Aug 2018
        • 16
        The error indicates that Zabbix encountered a primary key constraint violation when trying to sync history data into its PostgreSQL database. Specifically, a record with the same (itemid, clock, ns) values already exists in the history table. Here's a breakdown and how you can address it:
        Cause:
        Duplicate Data: Zabbix is trying to insert a duplicate record into the history table. This typically happens if:
        There was a previous failed sync attempt.
        The database already contains the record but Zabbix is unaware due to desynchronized metadata.
        Concurrency Issues: High system load or overlapping sync jobs might cause the same record to be processed multiple times.
        Database Corruption or Manual Insertions: A manual or automated process may have inserted conflicting data directly into the database.
        Identify the Duplicated Record
        Use the details from the error message (itemid=290017, clock=1733853518, ns=15802223) to inspect the database. Run the following SQL query:
        SELECT * FROM history WHERE itemid = 290017 AND clock = 1733853518 AND ns = 15802223;
        This resulted in Zabbix Query failed causing the Zabbix server to crash post-startup.
        Additionally, for performance optimization to monitor 500+ hosts ulimit values for Zabbix user must be set to 65535 and open files limit must increased to at least 10000 ; ulimit -Hn ; ulimit -Sn
          Your own log...same process number here (177716)
          177716:20241210:133929.712 Got signal [signal:11(SIGSEGV),reason:1,refaddr:(nil)]. Crashing ...
