TrueNAS - no trigger or alert when ZFS pool is above defined percentage value.
  • beriapl
    • Jun 2020
    I successfully set up monitoring for my TrueNAS by official SNMP integration/template from zabbix.
    However, I have a strange issue with alerts about ZFS pool usage - they are not generated, and I have no idea why.
    I have zabbix 7.0.6 and I'm using TrueNAS CORE by SNMP.
    There is a trigger definition using two macros:
    {$ZPOOL.PUSED.MAX.WARN} - value 80
    {$ZPOOL.PUSED.MAX.CRIT} - value 90
    All values are watched properly, but my zpool is currently at 99.32 usage and I never got any alert on the zabbix.
    • 5002
    How much free space you still have?
    If you look here https://www.zabbix.com/integrations/truenas, then it says "2 conditions have to match"...
    Two conditions should match:
    1. The first condition - utilization of the space should be above {$ZPOOL.PUSED.MAX.CRIT:"{#POOLNAME}"}%.
    2. The second condition - the pool free space is less than {$ZPOOL.FREE.MIN.CRIT:"{#POOLNAME}"}
    by default free space is set to 5G...
    So if you still have more thatn 5G of gree space there... full condition is not matched.. only half..
    • beriapl
      • Jun 2020
      Ok, I've got like 200GB free space left, but is there any way to remove that condition and base only on %?
      ZFS do not work well if it is more than 80%
      That's actual alert on TrueNAS: Space usage for pool "backup" is 96%. Optimal pool performance requires used space remain below 80%.
        • 5002
        Remove part of the trigger condition ...
