Zabbix 7.2.0 packages
  • CharlieRoot
    • Oct 2020
    • 15
    Can someone explain to me how to get the packages for zabbix 7.2.0? When I look at the repositories there is a new release, but no packages are available:
  • Tristis Oris
    • Sep 2015
    • 66
    zabbix-release folder contain packages.
    • Oni
      • Sep 2024
      You just have to change repository :
      wget https://repo.zabbix.com/zabbix/7.2/release/debian/pool/main/z/zabbix-release/zabbix-release_latest_7.2+debian12_all.deb
      dpkg -i zabbix-release_latest_7.2+debian12_all.deb
      apt update
      • Daniel4711
        • Jul 2014
        • 127
        Have a look in the Documentation.. 4 Installation
        Everything should be explained here
        • CharlieRoot
          • Oct 2020
          • 15
          apt update
          Obviously this is exactly what i did, like with any other upgrade. It worked a day after posting this message, i didn't change anything on our end.
            It might be, that release process and creation of all files takes "a little bit of time"... some links might be updated before actual files arrive... I guess it would be better to first create and then change links etc... but.. I really dont know how it is done there in Zabbix...
