Help Using a Macro on a Template
  • Txurrispo
    • Dec 2024
    Hi All.
    I have some questions about using a Macro on a Template.
    The official documentation is here: https://www.zabbix.com/la/integrations/meraki
    I have the template working, but autodiscover for a lot of devices that i dont want. On the docs there are a macro that can filter device names, but i dont know how use it on Zabbix.
    Description: This macro is used in devices discovery. Can be overridden on the host or linked template level.
    Default: .+
    I want to select what devices show or detect in discovery, but i dont know hoy edit a put a value.
    Could anybody help me?
    Regards.
    • 5008
    it is regex there... ".+" means "one or more of whatever".. so it matches everything. You need to construct a regex that suits your needs and matches only names that you need.
