configure: error: vpx_codec.h not found.
  • aprakash
    • Mar 2017
    • 21
    I am trying to compile zabbix in Linux Server release 6.6
    PHP Version: 5.5.38
    I am using below commands for compilation
    ./configure --with-apxs2=/tools/appsw/oracle/apache/bin/apxs --enable-bcmath --enable-mbstring --enable-sockets --with-mysql --prefix=/tools/appsw/oracle/apache/php --with-config-file-path=/tools/appsw/oracle/apache/php --with-oci8=/tools/utilsw/oracle/11gclient --with-gd --with-vpx-dir --with-jpeg-dir --with-png-dir --with-xpm-dir --with-freetype-dir --with-t1lib --enable-gd-native-ttf --enable-gd-jis-conv
    Getting below error
    checking for GD support... yes
    checking for the location of libvpx... yes
    checking for the location of libjpeg... yes
    checking for the location of libpng... yes
    checking for the location of libXpm... yes
    checking for FreeType 2... yes
    checking for T1lib support... yes
    checking whether to enable truetype string function in GD... yes
    checking whether to enable JIS-mapped Japanese font support in GD... yes
    How to fix this, since it is referring vpx_codec.h under /usr/local/include
    File vpx_codec.h does not exist under /usr/local/include..
    what package i need to install to fix this on Linux Server release 6.6
  • jan.garaj
    • Jan 2010
    • 506
    Try to install libvpx-devel package.
    • aprakash
      • Mar 2017
      • 21
      Thanks for the update.. I install libvpx-devel and now compilation looks good..
      However, i am getting issue in make
      Step1: Looks good
      ./configure --with-apxs2=/tools/appsw/oracle/apache/bin/apxs --enable-bcmath --enable-mbstring --enable-sockets --with-mysql --prefix=/tools/appsw/oracle/apache/php --with-config-file-path=/tools/appsw/oracle/apache/php --with-oci8=/tools/utilsw/oracle/11gclient --with-gd --with-vpx-dir --with-jpeg-dir --with-png-dir --with-freetype-dir - Looks good
      I am getting below in last while performing make
      Step2 : make
      /usr/bin/ld: /usr/local/lib/libvpx.a(vpx_codec.c.o): relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
      /usr/local/lib/libvpx.a: could not read symbols: Bad value
      collect2: ld returned 1 exit status
      make: *** [libphp5.la] Error 1
