Avaibility in grey with no error in the logs
  • PmGs
    • Nov 2024
    • 17
    I use Zabbix version 7.06, agent2 in active mode and the "Linux by Zabbix agent active" template, most of my hosts have an availability icon in grey (unknown).
    According to this link https://www.zabbix.com/documentation...unreachability
    the faults causing this state are seen in the server logs by filtering "failed" and the name of the "host".
    For a host, I had a "vfs.file.contents[ "/sys/class/net/enp1s0/speed"]" defect, I disabled the item concerned but my status remains in grey and I don't see a "failed" defect in the logs anymore (with DebugLevel=5)
    The doc is not totally up to date? And in this case, does a reader have an idea how to define the origin of this state?
    Thank you in advance.
  • Answer selected by PmGs at 12-12-2024, 15:02.
    PmGs
    • Nov 2024
    • 17
    Active agent, I found an error in the agent logs (/run/zabbix did not exist).
    Ok now.
    • PmGs
      • Nov 2024
      • 17
      Ok now.
