Zabbix Web Interface
  • welaish
    • Jun 2019
    After Upgrading to 7.2 I cannot reach the zabbix interface. Server is working fine and data base is upgraded successfully. but whenever I try to access the login page I get the below. everything seems perfect in place. I guess its Apache error but I am clueless how to solve this problem.
    <?php
    ** Copyright (C) 2001-2024 Zabbix SIA
    ** This program is free software: you can redistribute it and/or modify it under the terms of
    ** the GNU Affero General Public License as published by the Free Software Foundation, version 3.
    ** This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY;
    ** without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    ** See the GNU Affero General Public License for more details.
    ** You should have received a copy of the GNU Affero General Public License along with this program.
    ** If not, see <https://www.gnu.org/licenses/>.
    require_once dirname(__FILE__).'/include/config.inc.php';
  • Brambo
    • Jul 2023
    • 256
    I looks like apache isn't parsing php files if you see this.
    Check if php is still installed and maybe restart apache? (I'm no linux guru)
    • welaish
      • Jun 2019
      Fixed with 2 commands. it seems that the apache stays linked somehow to the old verion 7.4
      sudo a2enmod php8.1
      sudo systemctl restart apache2
