Is it possible to set event tags using API?
  • StormScorpion
    • Feb 2024
    • 22
    is it possible to set tags to an event using API?
    Some Media Types (Jira, Zammad for example) use tags to set an link to the created ticket. I use a webhook to call a Lambda on AWS with some logic (join multiple problems of one host into a single ticket) which will be processed asyncronous. So during the runtime of the webhook I dont know the ticket id. THerefore I want to set it later using API, but in the docs there are only get methods.
  • Answer selected by StormScorpion at 17-12-2024, 11:01.
    cyber
    I dont think you can.. All tags are gathered together during the event (including the tags created by action like webhook). So if you do not get any ID-s back and do not process them in the webhook, then you have no options to add that tag later..
    Theres always insert to problem_tag table... I do not want even to guess, what might happen.. you need eventid and tag name and its value... ​​
