Help Configuring a Commercial Wildcard SSL Certificate with Zabbix 7.0.5
  • jburysom
    • Jun 2024
    • 16
    Hello there,
    I’m running zabbix-server 7.0.5 with httpd-2.4.37-65, php-fpm-8.2.13-1 and mysql-community-server-8.0.37-1 on Red Hat Enterprise Linux 8.10.
    We have a wildcard SSL certificate in PEM format for our organization. I would like to install this SSL certificate on our zabbix server to secure the web front end. How do I go about accomplishing this? I cannot seem to find anything on configuring Zabbix with a STAR certificate.
    On an apache server you would normally install “mod_ssl” and update the following options in the /etc/httpd/conf.d/ssl.conf file: SSLCertificateFile, SSLCertificateKeyFile, SSLCertificateChainFile. We would also enable port 443 and setup a firewall redirect.
    I'm not sure how this would work with the incorporation of php, etc. From what I have been coming across it doesn't seem like it's as simple as above with Zabbix… Any help would be greatly appreciated.
    Thanks!
    You just go and secure your apache... php is already "behind" the http server, so you dont need to do anything...
