cannot establish TLS SSL_connect() timed out
  • pumboss
    • Dec 2024
    Hello!
    I started to change zabbix proxies to docker containers and get unknown error
    211:20241216:120011.639 Unable to connect to [zabbix]:10051 [TCP successful, cannot establish TLS to [[zabbix]:10051]: SSL_connect() timed out]
       211:20241216:120011.639 Will try to reconnect every 1 second(s)
       211:20241216:120038.212 Connection restored.
    These errors could be repeated 3-10 times per hour, jitter between connection restore is 0.3-15 sec.
    Its only trouble and proxies works good
    Options to start container:
    zabbix/zabbix-proxy-mysqll-6.0-latest (i tried ubuntu and alpine with same result)
              ZBX_TIMEOUTE: "20"
              ZBX_TLSACCEPT: "psk"
              ZBX_TLSCONNECT: "psk"
              ZBX_TLSPSKFILE: "/etc/zabbix/zabbix_proxy.psk"
              ZBX_TLSPSKIDENTITY: "{{ proxy_name }}"
              ZBX_CACHESIZE: "256M"
              ZBX_STARTPOLLERS: "25"​
    With same options regular zabbix_proxy works without this errors (same network, same addresses)
  • Brambo
    • Jul 2023
    • 250
    I looks like docker values you posted.
    Looking at a local example the
    ZBX_TLSPSKFILE=/etc/zabbix/zabbix_proxy.psk
    ZBX_TLSPSKIDENTITY=your-configured-identity-without-quotes
    We don't have any quotes and have env-var=value
    See example here https://hub.docker.com/r/zabbix/zabbix-proxy-sqlite3
    • pumboss
      • Dec 2024
      This quotas only in docker runner
      Here's actual config from zabbix-proxy container
      cat /etc/zabbix/zabbix_proxy.conf |grep -v "^#" | grep -v "^$"
      Server=zabbix.tprogress.local
      Hostname=Zabbix-Proxy-PP
      LogType=console
      DBHost=Zabbix-Proxy-PP-mysql
      DBName=zabbix_proxy
      DBUser=root
      DBPassword=HereSomePassword
      DBPort=3306
      StartPollers=25
      CacheSize=256M
      ExternalScripts=/usr/lib/zabbix/externalscripts
      FpingLocation=/usr/sbin/fping
      SSHKeyLocation=/var/lib/zabbix/ssh_keys
      User=zabbix
      SSLCertLocation=/var/lib/zabbix/ssl/certs/
      SSLKeyLocation=/var/lib/zabbix/ssl/keys/
      SSLCALocation=/var/lib/zabbix/ssl/ssl_ca/
      LoadModulePath=/var/lib/zabbix/modules/
      TLSConnect=psk
      TLSAccept=psk
      TLSPSKIdentity=Zabbix-Proxy-PP
      TLSPSKFile=/etc/zabbix/zabbix_proxy.psk
      Any suggestion about [TCP successful, cannot establish TLS SSL_connect() timed out] ?
      • Brambo
        • Jul 2023
        • 250
        The PSK should be a HEX string of max 512 Chars and should match with the PSK value you have setup in with zabbix frontend.
        When you have PSK mismatch you can get a similar error messages
        • pumboss
          • Dec 2024
          Yes, its popular mistake but i use only 24 hex symbols. Once again - proxy works - it connected with server but log full of this error, but it doesnt affect work
