Report required for bandwidth utilisation report
  • chappo
    • Dec 2024
    I’ve got SNMP set up to poll a WatchGuard firewall in Zabbix, and I’m trying to generate a bandwidth utilisation report. Specifically, I’m looking to:
    Visualise peaks and averages over a 7-day period for traffic on the interfaces.
    Anyone got experience setting this up or tips on the best way to achieve it? I’d greatly appreciate your guidance!
    Any advice, examples, or step by step guides would be amazing.
    Thanks in advance!
  • mrnobody
    • Oct 2024
    • 61
    Inside Zabbix you can create triggers for this (to have a historic of incidentes, graphs, dashboards, etc), did you customized the template are you using?!
    Using API to integrate to Graphana, Power BI and others, you can manipulate data collected by Zabbix, defining ([in a easier way*] those data, to create graphs and more metrics as you wish, and can craft
