Best Practice of Action Configuration
  • kelwoo
    • Nov 2013
    Hi All,
    I am now using Zabbix to monitoring 500 hosts which many hosts groups/application/templates have been configuration. However, the configuration of Action is headache to me now since the overlapping the conditions of action lead to the action being triggered several times.
    For example, the file system full of server A is belong to [host group A] and [application X]. However, I have 2 actions configured separately for host group A and application X, each of the action will trigger email to same group of user. Eventually, 2 emails are sent to them. I just quoted the simplified situation, but scenerio are similar.
    Is there any guide line for me to config action in smarter way?? I know it is dump config now...
  • batchenr
    • Sep 2016
    • 440
    Originally posted by kelwoo
    Hi All,
    cant you define in the action to send by :
    triiger=PROBLEM
    host Group = A
    and thats is ?
    • kelwoo
      • Nov 2013
      Sorry for my mistake, what I mean is :
      I have 2 actions configured separately for host group A and application X, each of the action will trigger email to different group of user. Eventually trigger event for Application X will also trigger the event for host group A since items of Application X is belong to host group A.
      I need to define many exceptions to prevent mistakenly sent sms/email
      thx!
      • batchenr
        • Sep 2016
        • 440
        thx!
        you got me confused.
        can you post screen shot of action and all tabs inside ?
