Which "Virtual machine CPU usage"
  • cezve
    • Mar 2024
    Hi, I'm using zabbix server 7.0.2. Recently I added vcenter servers (version 8.0.2) by the manuel below;
    Sometimes zabbix alert me about Virtual machine CPU usage. But it does'nt say which machine cpu usage is high.
    There is a mail about the problem but host is always vcenter name;
    Click image for larger version  Name:	alert.png Views:	1 Size:	8.0 KB ID:	496369
    How can I fix this.
  • Blevar
    • Jan 2025
    • 68
    You could add a macro with the host name in the mail template:
    {HOST.NAME}
    • cezve
      • Mar 2024
      There is also {HOST.NAME} in the mail template.
      My problem is all of the virtual machine cpu/memory changes alert send by Host: dr-vcenter. I want to see which virtual machine has cpu/memory problem
      • bolemanyi.attila
        • Apr 2025
        Did you find a solutions for this? I have hundreds of mails per day about the same alert, but I do not know which VM generates the alert messages. Annoying...
        • bolemanyi.attila
          • Apr 2025
          Update for this topic: the message comes from the VMware Event Log item. I should find a way to get the VM id for the logged event. Can anyone help with this? BTW, I use Zabbix 7.0.11.
          • matidr
            • Jan 2020
            I think the only way (ways) to solve this is to get VMware to send the information to Zabbix in the event to Zabbix and then see how to get it, or to get the alert from somewhere else. Zabbix Triggers this alert when the event shows up on an Item that collects all the active alarms on the vcenter server (Get alarms), the event reveived never identifies the VM with the issue.
            Still dont now how though
