Cannot install Zabbix on ubuntu Noble!! Please Help! Been stuck for a week!
  • kanon
    • Dec 2024
    • 13
    Ubuntu os version 24.04
    Im following instructions from here-
    https://www.zabbix.com/download?zabb...ubuntu&os_vers ion=24.04&components=server_frontend_agent&db=mysq l&ws=apache
    Stuck on step d
    on this command -
    zcat /usr/share/zabbix/sql-scripts/mysql/server.sql.gz | mysql --default-character-set=utf8mb4 -uzabbix -p zabbix
    Which gives me the output -
    root@hpserverkkb:~# zcat /usr/share/zabbix/sql-scripts/mysql/server.sql.gz | mysql --default-character-set=utf8mb4 -uzabbix -p zabbix
    gzip: /usr/share/zabbix/sql-scripts/mysql/server.sql.gz: No such file or directory
    What on earth is going on here?
    There really is no such directory as ive checked on the cli myself.
    Dont see that server.sql.gz file as well anywhere.
    Ive followed all the steps before that without fail diligently.
    Thank You!!
  • ftb3
    • Sep 2024
    Did you do the boldered part from step b?
    # wget https://repo.zabbix.com/zabbix/7.2/r...u24.04_all.deb
    # dpkg -i zabbix-release_latest_7.2+ubuntu24.04_all.deb
    # apt update
      was "zabbix-sql-scripts" package properly installed?
      • kanon
        • Dec 2024
        • 13
        its been a while but yes i was able to get it fixed
        • Jaceqp
          • Mar 2026
          • 19
          If so it'd be a nice touch to post the solution...
