Regular Expression
  • Mun
    • Sep 2016
    • 67
    Regular Expression
    My discovery rule appears NOT Supported with below error, any idea what's is going on?
    Global regular expression "Network IP Address Discovery" does not exist
    Thanks.
  • onallion
    • Mar 2016
    • 131
    Your rule relies on a global regular expression that seems to not exist on your Zabbix server.
    Go to Administration->General->In the drop-down box choose "Regular Expressions". There you will see all of your regular expressions.
    Probably you added a template that requires you manually add that expression, and you did not.
