hello,
my setup is as follows:-
[zabbix (2.4.x) + db] <--> [proxy (2.4.x) + db] <--> infra
8 core 16 GB RAM VM 4 core 12 GB RAM VM
the proxy is in active mode.
I am trying to monitor a couple of AD devices through the proxy using the templates available on zabbix share.Most of the data points in the templates are perf counters. In total about 400 data points on 2 servers with a 5 minute frequency.
The issue is that there are gaps in the data when the servers are monitored through proxy ( along with queue buildup ). However , the same are monitored fine through the zabbix server.
I have sufficient pollers at the proxy and can see that their busy percentage is very small. Also OS stats on the proxy are well within range.The free cache statistics are also at 100%.
Any pointers would be very helpful.
regards
gunner
regards
gunner
