Issue with "host.update" in Zabbix API - templates_clear removes all templates
  • Giacomo_Boria
    • Jan 2025
    I’m new to the forum, and I’d like to thank you in advance for your support.
    On my Zabbix server (version 6.0 LTS), I need to modify several hosts to replace an existing template with a new/different one.
    Given the large number of hosts and the need to make additional changes, I decided to use a Python script. I based my script on the official documentation, specifically this page:
    Problem:
    When I execute the host.update request with the templates_clear parameter to unlink and clear a specific template, all templates associated with the host are removed, not just the one specified.
    Here’s the code I’m using:
    def remove_template(auth_result, hostid, templateid_to_change):
        auth_token = auth_result["result"]
        host_update = {
            "jsonrpc": "2.0",
            "method": "host.update",
            "params": {
                "hostid": hostid,
                "templates_clear": [
                        "templateid": templateid_to_change
            "auth": auth_token,
            "id": 1
        response = requests.post(zabbix_api_url, data=json.dumps(host_update), headers=headers, verify=False)
        create_result = response.json()
        return create_result
    Question:
    Has anyone encountered a similar issue? Am I using the API correctly, or am I missing something?
    Thank you very much for your support!​
    • 4993
    Looks ok...
    tested with following, removed only one specified template...
    from zabbix_utils import ZabbixAPI
    zapi = ZabbixAPI(url="your api url")
    zapi.login(token="your access token (generate from UI)")
    zapi.host.update(
        hostid=<insert your hosts id here>,
        templates_clear=[
                "templateid": <insert your template id here>
    using native python library .. https://github.com/zabbix/python-zabbix-utils
    • Giacomo_Boria
      Giacomo_Boria commented
      Thanks for your response.
      I tried the suggested solution, but unfortunately, the result is still the same: when I run the code, all templates associated with the host are cleared, not just the one specified.
      Here is the updated code I’m using now:
      def remove_template( hostid1, old_template):
      api.host.update(
      hostid=hostid1,
      templates_clear=[
      "templateid": old_template
      Is this behavior expected? Or is it a bug in the API? If anyone has successfully managed to unlink a single template without affecting others, I’d greatly appreciate any insights.
      Thanks again for your help!
