Commas in macros
  • vanessa
    • Oct 2024
    • 38
    Commas in macros
    What is the way or best practice (if even possible) to have commas in macros, when they are used in keys?
    key[arg1,{$MACRO}]
    The commas in the macro is interpreted as argument separators. I find a few bug reports and forum posts addressing this without a solution, documentation or best practice. People have tried to quote the macro etc without success.
    According to some posts there seem to be an undocumented feature where you use double-square-brackets [[ ]] which has some kind of function (yet, it would be a syntax error according to the official documentation https://www.zabbix.com/documentation...items/item/key).
    Rumor has it that the sold support (important for the zabbix business model) have access to secret documentation. Is it available for purchase?
  • Answer selected by vanessa at 08-01-2025, 11:43.
    vanessa
    • Oct 2024
    • 38
    Bug fixed in 7.0. Resolving the thread.
    • vanessa
      • Oct 2024
      • 38
        • 4969
        I am pretty sure that support has a lot of additional information from solved cases. But due to the nature of such info (client confidentiality etc) you cannot get direct access to it (even if you buy support). But based on your requests towards support, they can search it and interpret it and give you the answer.. I guess this is pretty same for every company providing support for its product..
