I have fresh install the zabbix server and database on the same server.
However, the service is not able to start.
Below is the error message
[zabbix@zabsrv system]$ sudo systemctl start zabbix-server.service
Job for zabbix-server.service failed because the control process exited with error code. See "systemctl status zabbix-server.service" and "journalctl -xe" for details.
[zabbix@zabsrv system]$ systemctl status zabbix-server.service
รข zabbix-server.service - Zabbix Server
Loaded: loaded (/usr/lib/systemd/system/zabbix-server.service; enabled; vendor preset: disabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2017-03-17 16:55:26 +08; 4s ago
Process: 5425 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=1/FAILURE)
Mar 17 16:55:26 zabsrv.sing.com systemd[1]: Failed to start Zabbix Server.
Mar 17 16:55:26 zabsrv.sing.com systemd[1]: Unit zabbix-server.service entered failed state.
Mar 17 16:55:26 zabsrv.sing.com systemd[1]: zabbix-server.service failed.
[zabbix@zabsrv system]$ journalctl -xe
Unit zabbix-server.service has begun starting up.
Mar 17 16:58:41 drt-zabsrv.sing.seagate.com zabbix_server[5523]: zabbix_server [5523]: invalid entry "This is a configuration file for Zabbix server daemon" (not following "para
Mar 17 16:58:41 drt-zabsrv.sing.seagate.com systemd[1]: zabbix-server.service: control process exited, code=exited status=1
Mar 17 16:58:41 drt-zabsrv.sing.seagate.com systemd[1]: Failed to start Zabbix Server.
-- Subject: Unit zabbix-server.service has failed
-- Defined-By: systemd
-- Unit zabbix-server.service has failed.
-- The result is failed.
Based on https://www.zabbix.com/forum/showthr...service+failed, seems like the pid file got wrong.
So i have done steps below :
1. check mysql socket in /etc/zabbix/zabbix-server.conf and have it modified from /tmp/sock to /var/lib/mysql/mysql.sock
2. Tried to chekc on the zabbix-server.pid on zabbix-server.conf and have modified it from /var/run/zabbix/zabbix_server.pid to /run/zabbix/zabbix_server.pid which is the same with
Error message from /var/log/zabbix/zabbix_server.log
17438:20170317:153249.957 Starting Zabbix Server. Zabbix 3.0.8 (revision 65976).
17438:20170317:153249.957 ****** Enabled features ******
17438:20170317:153249.957 SNMP monitoring: YES
17438:20170317:153249.957 IPMI monitoring: YES
17438:20170317:153249.957 Web monitoring: YES
17438:20170317:153249.957 VMware monitoring: YES
17438:20170317:153249.958 SMTP authentication: YES
17438:20170317:153249.958 Jabber notifications: YES
17438:20170317:153249.958 Ez Texting notifications: YES
17438:20170317:153249.958 ODBC: YES
17438:20170317:153249.958 SSH2 support: YES
17438:20170317:153249.958 IPv6 support: YES
17438:20170317:153249.958 TLS support: YES
17438:20170317:153249.958 ******************************
17438:20170317:153249.958 using configuration file: /etc/zabbix/zabbix_server.conf
17438:20170317:153249.958 cannot set resource limit: [13] Permission denied
17438:20170317:153249.958 cannot disable core dump, exiting...
Any idea what cause the error ?
Thank you very much in advance
