Configure LDAP/LDAPS
  • andreas202k
    • Jan 2025
    I am new to Zabbix and am trying to configure LDAP/LDAPS.
    zabbix_server (Zabbix) 7.0.6
    Ubuntu.
    My AD support both LDAP and LDAPS. I have confirmed that i have connection from the Zabbix server with ping.
    I am not able to get LDAP or LDAPS to work, the ldapsearch commands are below, guess LDAPS search command works?
    (for this to work I had to enable the "TLS_REQCERT never" setting in ldap.conf file)
    If i try LDAP search I get this message
    I have configured the settings like this
    LDAP does not work either
    Not sure whats missing here, i thought LDAP should be easy to configure, but I have seen several posts on the internet around this, but dont seem to find the correct fix.
    There is no firewall between my zabbix server and dc`s
    Thanks for any reply.
    /R
    Andy​​​
  • Blevar
    • Jan 2025
    • 68
    Could you provide more information on how you tried to configure the LDAP settings?
    You can read more on this topic: https://www.zabbix.com/documentation...ntication/ldap
