How to update zabbix agent and how to set up active monitoring?
  • jnoas123
    • Jan 2025
    I'm trying to enable active monitoring on some linux devices (they are running on ubuntu 18.04.6 LTS).
    The agent that is currently on there is quiet old (too old i think for active monitoring) so how do i update this one or remove it so i can install a new one?
    For the agent configuration which options should be present to allow it to use active monitoring?
    Thank you so much if you can help with this question.
  • Answer selected by jnoas123 at 16-01-2025, 10:08.
    kyus
    • Feb 2024
    • 203
    Hey!
    You can go to https://www.zabbix.com/download?zabb...gent_2&db=&ws= choose the version of the agent that you need and follow the installation instructions.
    For the active agent you need to setup the ServerActive and Hostname parameters in /etc/zabbix/zabbix_agentd.conf or /etc/zabbix/zabbix_agent2.conf (accordingly to the agent you installed).
    In the frontend you need to create a host with the same hostname you setup in the agent config.
    • kyus
      • Feb 2024
      • 203
      Hey!
      • troffasky
        • Jul 2008
        • 639
        I don't know why a hard-coded hostname is the default in the Zabbix agent config. Literally no device I ever installed the agent on is called "Zabbix server", so it's guaranteed to be wrong. I always comment out Hostname= and then the hostname is just the hostname!
        • troffasky
          troffasky commented
          There is exactly one time this works - when you install Zabbix server, a host is added called "This Zabbix server" and has a hostname of "Zabbix server".
        • 4993
        I have not installed any clean agents for ages (corporate env and automated installs), but docs indicate that hostname is by deafult set by "HostnameItem" and HostnameItem defaults to "system.hostname"
        Is it really "Zabbix server" there if you install a clean agent by hand
        • troffasky
          • Jul 2008
          • 639
          In zabbix_agentd.conf shipped with Zabbix packages from Zabbix repos, HostnameItem is commented out and Hostname is "Zabbix server". Amusingly, it also says:
          # Default:
          # Hostname=
          but if config file shipped in vendor packages doesn't do what is "default", then what does "default" even mean?
          I cannot be the only person who finds this a bit odd.
          If you use packages from Debian repos, both are commented out by default.
